Results 1 to 6 of 6
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Are aftermarket MAF's any good?
    They are about 1/3 the price of OEM... Made In Germany supposedly?! Would it be worth it? Accurate at all?
    ΜΟΛΩΝ ΛΑΒΕ
    Dec 05 2007
    Re: Are aftermarket MAF's any good?
    I would not replace certain components with anything but OEM. One of them being the MAF. FWIW, I just bought a replacement and it is Bosch. Hitachi seems ok though.
    Mar 04 2007
    nothing
    nowhere
    Thing is, it says that it is made in germany and gives a Bosch number... They don't stated that it is Bosch... If it is, I will go ahead and buy it!
    ΜΟΛΩΝ ΛΑΒΕ
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    link? unless it's on ebay, i don't want to snake it from you. if not, link it up.. i need a new maf also.
    Dec 05 2007
    Some listings use the Bosch part number and part number for VW just for referance. For example, my Bosch part number is 0280218063, and the VW part number is 06A906461L(X for replacement).
    Edit: Too late, I got lucky with mine. Link.
    Veteran Member Four Rings Mawhitey's Avatar
    Jan 20 2005
    99 AJL TQS
    UK
    Unless it is OEM i would stay away, i tried 2 and had different results from both and it was during the swapping around that i dropped the clip into my SP1 turbo. I went OEM after that and all of the runnig probs and low readings went away.
    -Mark -
    .2008cc Stroker, K04064, ME7.5, Miltek, and other goodies
    My k04064 , ME3 DBC to ME7.5 DBW build thread
