Results 1 to 40 of 42
    Dec 06 2007
    Calgary, AB, Canada
    Fun times at the track last night...
    Here's a vid of a pass I made last night. I was running a very conservative base map for software because I just barely threw the water/meth kit in the car yesterday afternoon, so I didn't have time to tune it at all and I didn't want to do any damage to the car. Track is at 4000ft elevation, for more details check out the caption...
    12.7 @ 109
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Re: Fun times at the track last night...
    You need a better camera man. I look forward to seeing what a tune will due to the times.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    109 for a stage 3 car is not too fast eh?
    Feb 17 2004
    Sterling, VA
    Quote Originally Posted by ThirdStrike View Post
    He's at 4000 Ft. above sea level. Ambient air pressure drops .5Psi for every 1000Ft. above sea level. Less dense air equals less actual oxygen to burn and thus less HP. Yada, yada, yada.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Dec 06 2007
    Calgary, AB, Canada
    ^^Thank you
    The track has the reputation of being the 2nd slowest track in North America for 2 reasons mainly: It's the 2nd highest (the only one higher is in Colorado), and the prep work is horrible. As you can tell, I had a hard time getting traction, and kept tweaking my launching technique because there was so much rubber at the start line that I kept spinning my wheels. My 60' were 1.8-1.9. This was the opening night for the season, we'll see how I do after a good tune and some modification to the launch.
    My highest trap was 113.
    For reference, an '07 Carrera 4S ran a 15.0, a modded 300ZX fairlady z ran a 14.5, a SC Cobra ran a 13.7, and a sprayed busa ran 11.1.
    Veteran Member Four Rings jasonsowers's Avatar
    Feb 18 2007
    Denver, Colorado
    Bandemere is in Colorado. Good time dude!
    2002 B5 S4 Laser Red Avant - Tial 605 EPL tuned
    2000 B5 S4 Brilliant Black - Stage 3 K04/RS6 hybrid sedan EPL tuned
    2006 Cayenne Turbo - Stage 2 EPL tuned
    2006 Audi B7 A4 Avant 2.0t 6mt - Stage 2 EPL tuned
    2013 Phantom Black Pearl Effect 3.0t Q5
    2014 Monsoon Grey SQ5 - Stage 2 EPL tuned
    Stage 3 Forum Advertiser Four Rings Matt@JHM's Avatar
    Feb 24 2007
    2001.5 S4 Stg III
    Central California
    Nice times considering the elevation and track conditions, keep it up.
    JHMotorsports Shop - (209) 968-0077 - [email protected]
    2001.5 Audi S4 JHM Stage III
    Lots 'o Goodies
    Apr 11 2008
    00 s4 90 crx
    High Point, NC
    Congrats on the times. I guess some people dont understand how much elevation can hurt you...and 4000ft is like nosebleed high lol. Consdering the elevation and the fact that you were on a conservative basemap, id say this was a really respectable time.
    2000 Brilliant Black S4
    -DNA Catback, Piggies, Darintake w/ITG panel filter, 710n's, 034 TBB, 034 F hose, Vast clutch, JHM shifter & bushings, Vogtland/Koni's, Hotchkis Sways, ECS 12.5mm spacers
    2010 Honda Civic Ex Sport Auto
    -Stock daily driver/panty dropper
    2014 Fiat 500 Sport
    -Stock cone dodger for now. Suspension coming soon.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    my bad.
    what did the s/c z06 trap?
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Quote Originally Posted by Daft View Post
    op; were you seeing less than normal boost levels?
    im pretty sure you get the same boost at elevation as you would at sealevel...
    Feb 17 2008
    Ottawa Ont.
    sigh....
    Account Terminated Four Rings
    Nov 09 2007
    Si,NY
    Quote Originally Posted by The_Jerbel View Post
    ^^Thank you
    Holy Bejusus batman. Altitude or not,11.1 better have been a messed up launch, then the bike stalled out from running outta gas so he had to run grab a gas can,top up and continue his run with no pause on the timer for all the complications and not averages for a stretched and sprayed BUS.
    Active Member Four Rings ///M3 TO S4's Avatar
    Feb 09 2007
    Charlotte, NC
    you always say the smartest things in all your threads....
    Great runs jerbel for such a shitty track/conditions.....a stock s4 would be in the high 15's there I bet....
    Learn MANTH America!
    Stage 3....blah...blah...blah... : Sold
    Now: E36 M3 TURBO (GT35R)
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Quote Originally Posted by ///M3 TO S4 View Post
    wasnt a statement it was a question..
    being that i trapped 107 on a stage 2 tune with k03's id say 109 is not that fast for a vast stage3... but im wrong a lot.
    requested boost = actual boost at any elevation if your car is running right... but you guys are right less dense air = less hp.
    im /done
    Jan 11 2007
    Salt Lake City, Utah
    ^^Thank you
    What's the elevation? We've got Rockymountain Raceway here that is like 4300ft. IIRC. On friday a viper ran like consistient 13.5's
    Feb 17 2004
    Sterling, VA
    Psia = ambient air pressure.
    Psig = gauge pressure.
    Lower ambient air pressure (Psia) means less O2 concentration. Boost (Psig) should be the same since the ECU is requesting whatever the program says. Therefore Psig would not go lower than the program asks for. If it were very cold (like winter), then you could possibly see less boost since O2 concentrations are higher. However this is assuming that the N75 is controlling boost. A MBC cannot compensate for air density changes. The N75 can be regulated based on the MAF readings.
    My explination about ambient air pressure is only to relate to O2 in the ambient air and thus the lower amount of O2 to mix with fuel entering the combustion chamber.
    O2 is the oxidizer for the fuel to ignite. Less oxidizer results in less powerful combustion. Less powerful combustion results in less force against the pistons.
    Brett - Moderator
    Issue?: email me.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    as the same goes with hot air. i know.
    thanks
    /done again
    Dec 06 2007
    Calgary, AB, Canada
    my bad.
    The SC Z06 wasn't there that night, so I don't know.
    Dec 06 2007
    Calgary, AB, Canada
    I can only run about 23 psi spike and taper to ~20psi before the IAT's get too hot because the turbos are compressing the air more than normal to get that pressure at such high altitude.
    Turbos have to work harder to put out the same pressure at high altitude.
    Dec 06 2007
    Calgary, AB, Canada
    When I was stage 2 I was running a consistent 15.0 on that track.
    Dec 06 2007
    Calgary, AB, Canada
    Just for reference, in the dead of winter, I see roughly 250g/s of airflow, in the summer heat, I'm running about 230g/s. So the car typically runs more boost in the winter and less in the summer for that reason.
    Feb 09 2007
    Charlotte, NC
    im /done
    Did you see the explanation why he only trapped 109? He said it like....3 times.
    Account Terminated One Ring
    May 12 2008
    e36 turbo m3 rs6ed s4
    ferndale
    i ran a 12.6 at 108 here in michigan with a stage 2+
    Feb 09 2007
    Charlotte, NC
    Quote Originally Posted by m3ands4 View Post
    neat-o guy.....why would you post that here?
    Feb 17 2008
    Ottawa Ont.
    my cats breath smells like cat food.
    Dec 06 2007
    Calgary, AB, Canada
    Piggie and I have been cursing this high altitude and our crappy gas here. If ONLY I was in Michigan. They recently dyno'd a car at VAST in Michigan with a setup similar to mine, except that the car they used had a stock airbox, I've got full RS4 air intake components up to the y-pipe. The car was running a stock tune, only hitting 21 psi and holding that to redline. It dyno'd ~410whp. THIS IS IN MICHIGAN, much much closer to sea level than Calgary. That car might be doing 370 or so here.
    Jan 14 2008
    00 S4
    Cranbrook BC
    Bring your stage2+ to Calgary and see how it does. Calgarys track is a heartbreaker for sure STIs stock can bearly break into the 14s lol. Lots run 15s.
    Dec 06 2007
    Calgary, AB, Canada
    ^^2nd. I'll repost this just to remind some people....
    Veteran Member Four Rings JackalS4's Avatar
    Mar 01 2008
    Toronto, ON, Canada
    Holy elevation impact, Batman!
    Brilliant Black 2001 S4 - 6MT <3
    Dec 06 2007
    Calgary, AB, Canada
    ^^that and a crappy, unmaintained track surface...
    Feb 09 2007
    Charlotte, NC
    jesus...I just realized that that tool m3ands4 username is WAYYYYY too much much like mine....people are going to think i'm him now
    EDIT: HOLY.....FUCKING.....SHIT!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!! IT'S SPOOLINGGT2871!!!!!!!!! BWHAHAHAHAHAHAHAHHAHA THATS WHO THAT IS!!!!!!!!!!!!!!1111!!!1111
    Dec 06 2007
    Calgary, AB, Canada
    Time slip? thanks
    Feb 09 2007
    Charlotte, NC
    Time slip? thanks
    bro, check out the thread I just made.....lol this is going to get good...
    May 29 2004
    Calgary
    To back Jordan up on this... with my APR stage 3 I ran a 13.1 @ 111 with a 2.2...and a split F-hose on my race program
    and my Apr Stage 3+ A4 ran a 13.9 @ 103 w/ 2.0 (yeah, I suck at launching)
    Dec 06 2007
    Calgary, AB, Canada
    Mark, were those runs done on race gas? You mentioned the race program, what fuel were you running?
    May 29 2004
    Calgary
    The S4 run was on race gas.... A4 was 94 octane.
    Senior Member Three Rings BamfiNogaroS4's Avatar
    Feb 12 2008
    Denver, Co
    Quote Originally Posted by JohndoeS4 View Post
    If you get into the 13s here you have a pretty fast car lol I think its a little over 5800ft [O_O]
    Dec 06 2007
    Calgary, AB, Canada
    Quote Originally Posted by Audone View Post
    Oh ok, I was just curious because my car used to walk away from yours pretty hard when you had the torn boot and I was on a slower tune. I did these runs on pump and I would really like to see what I can run on race gas with a good tune.
    May 29 2004
    Calgary
    From what ive read.. 93 plus Meth would be close to a regular race gas program... and that appears to be true with those runs. Be interesting to see how they compare if I had Race and you did Meth, or when my Meth kit arrives!! hint hint...
    Dec 06 2007
    Calgary, AB, Canada
    I'm working on it! haha
    I'd like to run race gas with the meth kit and advance the hell out of the timing...
