Results 1 to 24 of 24
    Nov 08 2007
    will S4 suspension fit?
    I have a 1998 (04-98) Audi 2.8 Avant Quattro Manual
    Need to buy new suspension and have a friend who has a set of S4 suspension form a 2001 model, so Im curious, will it fit my car?
    THANKS!!
    E
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    Re: will S4 suspension fit?
    Will the S4 suspension fit your 2,8L V6 A4 Avant quattro? Yes
    Will it have any greater advantage over the correct set-up? No.
    Will it have your car sitting at the right height? No.
    Will it improve handling? Maybe.
    Established Member Four Rings Yaktizzle417's Avatar
    Aug 05 2007
    2000 A4 1.8TQM
    SpringVegas, MO
    Quote Originally Posted by Siena View Post
    Will it improve handling? No.
    Will I cockslap you for not finding the answer to one of the most asked questions ever by searching? Yes. (op, not Siena)
    ÖMGHI2Ü
    Photography
    Nov 08 2007
    Well, I wanted to lower the car some, but I also need new front shocks, figured that if I can get a set of S4 struts and springs it will lower the car, and at the same time replace the struts.
    So, S4 suspension will fit and will lower my car height over stock, correct? And how certain are we that the S4 suspension will fit my car?
    Edward
    Aug 05 2007
    2000 A4 1.8TQM
    SpringVegas, MO
    it will actually raise it from what I've seen. What you should do is buy his shocks and struts, and then grab some H&R Race springs.
    S4 stuff is strong enough to handle aggressive springs.
    ÖMGHI2Ü
    Photography
    Nov 08 2007
    Bro, take it easy, I have used the search tool, but at the problem lies in that the god damn suspension fitment is an issue, there seems to be special suspension for the A4 avant quattro, example, 1.8t and 2.8 are different, and then.... pre 02-98 and later differ.... if you have an answer, please let me know, I just need to know if the S4 suspension from 2001 will fit avant 1998-04 2.8QM. By the way, does it matter if the S4 is an avant or sedan?
    E
    Nov 08 2007
    alright, it will raise the car? shit, so fitment is an issue, it doesnt fit then?
    What if I just buy the springs? Am I going to kill my suspension?
    Edward
    Veteran Member Three Rings bandit's Avatar
    Feb 18 2006
    Roundhouseville
    s4 shocks with aftermarket springs is the way to go
    Enjoy yo self
    Aug 05 2007
    2000 A4 1.8TQM
    SpringVegas, MO
    Quote Originally Posted by edwardlarsen View Post
    E
    Lol, I was just giving you crap.
    Almost everything from the S4 and RS4 will fit on our cars.
    ÖMGHI2Ü
    Photography
    Veteran Member Three Rings big_greasy_taco's Avatar
    Apr 28 2008
    Houston, TX
    You could also just get some coilovers... may be a little easier
    Veteran Member Four Rings TMorris's Avatar
    Jul 09 2007
    B5
    Charlotte/Columbia
    Quote Originally Posted by big_greasy_taco View Post
    Dont think he wants to drop that kind of cash.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    i've posted about this countless times. avant is not special. it will raise the front. use the search function and people will stop making fun of you.
    Jim
    I Do Werk.
    Mar 09 2004
    nw michigan.
    the struts are the same. i've run both. they cannot handle race (poser) springs any more than stock a4 red struts. s4 springs alone are the worst thing you can do. coilovers are overkill for street cars. did I miss anything.
    Jim
    I Do Werk.
    Veteran Member Four Rings loustylez's Avatar
    Oct 03 2006
    2001 A4 2.8 QT
    kansas city
    likewise, onemoremile helped me confirm that sport suspension from a 1.8 should work on my 2.8 and that if anything the front will sit just a little lower. since sport suspension tends to be a little higher up front, maybe it will actually sit a little lower.
    in the past people have said it's a big no no to run 1.8 sports on a 2.8, but i'll take the word of someone who's actually done it. i'll be sure to post my findings afterwards of course.
    actually i was in the process of searching for if pre-facelift suspension is any diff than face-lift.
    the stock sport i'm buying is off a 2000+ and i'm 2001, but i have a friend with 1.8 sport off a 98, would that work?
    Nov 08 2007
    Im so terribly confused with the replied posts, one this one that.... and specify if the fitment is for avant or not, since there are differences with sedan and avant. Anyway, I ended up getting brand new koni's with H&R springs. Its a tight ride compared to previously, and I will be adding the bars to tighten it up some more...
    Anyone want to buy a NOS 75hp kit? It hauls ass with the 2.8, even steven with the S4.
    Late!
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    Im so terribly confused with the replied posts, . . . I ended up getting brand new koni's with H&R springs.
    Late!
    our job is done.
    Nov 08 2007
    HAHAHAAA! Thanks though guys!
    Dec 14 2006
    Halifax, NS, Canada
    This question is more common now then which chip or bov vs dv
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Nov 08 2007
    I dont know what that means (besides chip).
    Mar 09 2004
    nw michigan.
    What are the differences between a sedan an avant?
    I've got suspension from an S4 sedan coming. Something that hasn't been run here before.
    Jim
    I Do Werk.
    Oct 06 2004
    Minnesota
    I hav S4 suspension with 55k miles for sale
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Established Member Two Rings Flash's Avatar
    Oct 13 2006
    Earth
    Quote Originally Posted by onemoremile View Post
    So I found the right thread :D.
    Anyway, so are you saying that S4 suspension is basically the same or is the same as A4 sport suspension? Would the ride height be the same for both, ie lower than oem non-sport?
    I have a 98.5 2.8 QM and I think my suspension is getting to the end of it's life. My wife's A4 with sport suspension feels really good to me, and handles high-speed freeway bumps perfectly, while I'm left feeling like a bobble head with my oem non-sport.
    I already have a different fast-car, I just want to tighten-up my daily so I'm curious what you recommend.
    Mar 09 2004
    nw michigan.
    Nobody pays attention anymore...
    The struts are the same. The springs are not. S4 springs on an A4 put the front end way up in the air. The stock S4 front is higher than a stock A4 sport front and is several hundred pounds heavier. Reduce the weight and it gets even higher.
    Anyone that has driven a stock S4 won't want it's suspension. There is no advantage to running it.
    Jim
    I Do Werk.
    Oct 13 2006
    Earth
    Alright, thanks for the clarification.
