Results 1 to 19 of 19
    Apr 28 2008
    MilRockee
    B7 Navi unit swap
    Hey has anyone done the swap from the cd\tape unit to the navigation unit on a 06 B7? Is it difficult? What would a dealer charge to do this? How much is just the unit. I tried searching but didn't find anything. Thanks!
    Sep 15 2005
    Norwalk, CA
    Re: B7 Navi unit swap
    if you get a nav-plus unit plus harness and satellite antenna, it takes about 30 minutes to replace. You can get complete kits from www.navplus.us, or you may get lucky with good deals on ebay, but you would be taking your chances on ebay.
    I got mine off of ebay for about 1300(complete kit), and that was about 2 years ago. The unit should be a lot more available now, but with the weakening USD, i'm not sure how the price is affected.
    You can find install guides on navplus.us as well, so you should start by reading there.
    Peter
    Senior Member Three Rings B6QTRO's Avatar
    Nov 05 2005
    2007 A4Q S line 2006 A6 Avant
    Downers Grove, IL
    Quote Originally Posted by peta8368 View Post
    Peter
    X2 a very simple straight forward swap, do a search for Proxus he usually has them available.
    07 S line Titanium PKG
    Koni Coilovers | RS4 Grill | RS4 Recaros | Lamin X Fogs | Miltek Sport |OEM RS4 BBK | AWE Boost Gauge |
    APR | RNSE | 19" Champion Motorsport RF62's| Carbonio | Ultrac Sessanta | V1 Hardwired | RS4 Rear Sway |
    | Carbon Fiber Interior Trim | Blacked Out Front/Rear Rings | RS4 Pedals | Skid Plate | Phat Box | 35% Tint |
    Apr 28 2008
    MilRockee
    Thanks Guys!!
    Mar 02 2007
    Brisbane, Australia
    Are the nav units the same for each part or the world ? I mean, one from Germany for example can be configured to use english in the use interface, map data loaded for the specific region etc....
    Veteran Member Four Rings TSlice's Avatar
    May 18 2007
    Houston
    Yes, the hardware is slightly different, but you can configure the software of any RNS-E to work for your region as long as you get the correct unit for your car. Read more about this at www.navplus.us
    Registered Member Two Rings Ski DraGoN's Avatar
    Sep 24 2007
    fl
    I need to do this mod as well. Ebay sometimes has OEM units around $1000.
    Nov 12 2007
    Grand Junction, CO
    If you get a euro unit, you need to flash it with US Firmware. Once again, you can read more on that at navplus.us or go to www.nsxjr.com and he can help you with just about anything you need. Including the sale. He did mine.
    Veteran Member Four Rings initiala4's Avatar
    Feb 24 2004
    Land of the smiles
    Its pretty simple and straight forward. Takes roughly 30mins to do everything including connecting the harness. Also if you want the center display to work you need vagcom.
    2019 B9 RS4 - O.CT Tuning Stage 1 | Wagner Intercooler / Radiator | Ohlins R&T DFV | 034 Motorsports Dynamic + Sway bars | 034 Motorsports Transmission mount | Ignition Projects Coilpacks | HHC Rear rotor upgrade 370mm + Endless MX72 brake pads
    Formerly - 2003 Audi B6 A4 1.8T QM, 2013 VW Passat Variant 2.0 TSI
    Active Member One Ring greenhornet's Avatar
    Feb 22 2008
    528i, 125cc vespa ciao
    Texas
    The most difficult part is to remove the original radio. I did it one month ago and I was ready to return the RSN-E and find other options, until I got a handy 4" spatula and place it in between the radio and the console and just lever without a lot of effort. Remember to put the keys first. Then the GPS antenna was placed on the center of the dash board and ran the wires between the glass and the dash. After adding the adapter harness, just connect the unit and test it before pushing it back. I installed a bluetooth parrot 3000 evolution kit and it took me one minute to remove the radio. Everything else is very easy. Remember to wrap the harness in a light cloth of not after time some raddle noise will come out of there and will need to remove the radio again. Total Time I estimate 20 min. I got my unit from Vagnav and no problems. Good support too.
    Apr 14 2008
    2008 A4 SE Quartz Gray 2.0T
    How did you run the wiring to the back? Or did you just leave the GPS on the dash?
    Is pulling the RNS-E easy to do with the keys? Do you use all 4 keys at the same time?
    Quote Originally Posted by greenhornet View Post
    Sep 15 2005
    Norwalk, CA
    the EU unit actually is identical to US units except the words on one of the buttons. I am not 100% certain, but I believe EU units flashed to US firmware behaves just like US units.
    My unit is EU flashed to US firmware, and accepted update dvd without any problem (you pop it in, it updates the firmware. after that's done, you have new map and/or new features depending on what the new DVD contains)
    removing the radio/rns-e is quite easy with the correct radio key. Basically, you stick the 4 radio keys into the 4 slots, they each click into place, then you pull gently, and the radio/nav slides right out. The unit is about 5 lbs or so, and the way it mounts makes it want to slide in. So you will need to apply enough force to lift a 5lb object. Most kits you get should come with wiring harness, radio antenna adapter and gps antenna, so it's completely plug and play.
    My unit is actually up for sale now (i have decided to turn the a4 in after lease is up since maintenance in the long run will cost me a fortune) I will take some pictures of the removal process and post them in a day or two. If anyone is interested in the unit, PM me and we can talk.
    Peter
    Senior Member Two Rings ecks618's Avatar
    Mar 24 2008
    I actually wanted to do this too but I am a little confused about the GPS antenna. Does it need to be wired to the back of the cluster or does the B7 have everything already there.
    Nov 12 2007
    Grand Junction, CO
    You'll put it up under the dash. Works just fine there.
    Veteran Member Four Rings VZWalex's Avatar
    Feb 21 2008
    09 Q5 Ibis White
    Los Angeles, California
    I have mine in the dash behind the instrument cluster .. works fine. Simple swap took like 20-30mins max.
    15 Mazda Cx-5 metero Grey - Stock for now ...
    09 Q5 Ibis White. Prem+, B&O, ZiZa Pure Yellow Fogs, Clear Bra,Prestige tint,Tunerdome LED Plate Bulbs, VIM, Vag'd
    06 MkV 2.0T - Sold
    05 XB Silvermist. - Sold
    www.EurovisionProtectiveFilms.com
    Feb 22 2008
    Texas
    I left the antenna in the middle of the dashboard. It doesn't look bad. It always get 7 to 8 satellite signals. Yes you need all 4 keys. When gently pulling the key they keys come off, put them back and use the spatula method. It doesn't hurt the car or unit. Run the GPS wire between the dashboard and windshield. Doing it for the first time it may take a 3 or 4 minutes. Everything else is plug and play. If you need help I will be glad to help.
    ! ! ! YOU CAN DO IT ! ! !
    Feb 22 2008
    Texas
    Hey AudiWxGuy
    What kind of bluetooth you have? Audi factory or other? I installed parrot 3000 and have some issues.
    Veteran Member Three Rings Kid Red's Avatar
    Feb 05 2008
    Orlando, FL
    I will be switching out my tape deck for a NAV soon as I get my hands on one.
    So, removing the radio is a snap, done it twice for my Dice ipod connection, but my concern is running the gps to the shark fin, no one is doing that? Also, don't you have to vag something (I have the red display) first or the unit won't work and if so, what's the vag code?
    From navparts, WTF is video in motion? And how do I then go about adding Sat radio, HD radio and/or Bluetooth?
    2010 BMW 335i Sapphire Black + Black leather interior + Sport + Nav + PDC. Mods - Carbon Fiber wrapped interior - Gloss Black grill - 15% tint - more coming
    2006 A4 2.0T Quartz Grey + Black leather interior + Convenience. Mods - 19" VM RS4 reps - FK Silverline coilovers - APR 93 - Navigation - S4 mirror caps - S-Line E-Codes/Bi-Xenons - XenonMatch Hoen Fogs - RS4 sport pedals - LED License plate lights - black grill - 15% tint all around & More mods coming.
    Sep 15 2005
    Norwalk, CA
    you do not NEED to run the gps antenna to the shark fin, that is just where the stock antenna is. However, to get there, you will need to remove part of the headliner and some pillar cover. all plug and play kits should come with a separate antenna with a magnet. You can find plenty of location under the dash to put the antenna, just make sure it's somewher NEAR the top, not down low by your foot or something.
    I have my antenna by the fuse box, so it's easy to get to and easy to mount.
    RNS-E disables video signal while the car is in motion, therefore you can't drive and let the passenger watch movies. "video in motion" by pass something(i think the speed sensor) therefore rns-e does not cut off the video signal while your car is moving.
    sat radio and blue tooth both require extra pins on the wiring harness. so when you get your kit, the seller should specify (or let you choose) what type of harness it comes with. I BELIEVE you have 4 variations: nav only, nav + sat radio, nav + bt, and of course nav + sat radio + bt
    Also, the radio keys do not pop out if you use the correct ones. audi radio keys have a slot that locks in when you push it into the radio/nav unit. After you pull the unit off, you need to press a tab for each of the keys to release it. I will get more pictures for it tomorrow.
    Peter
