Results 1 to 10 of 10
    Senior Member Three Rings golovemd's Avatar
    Apr 12 2008
    2002 Audi A6 2.7t 6spd
    Connecticut
    spacers to clear control arm?
    I have a 2002 A6 2.7t. I just purchased this set of rims from a member on this board:
    rims and tires
    I mounted the passenger side tires to test them out. The rear fit ok, but in the front, the tire rubs up against the control arm. Can I use a spacer to use these?
    On the rims themselves, they are labeled et38 for offset.
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    Re: spacers to clear control arm?
    Normally we do between ET32 and ET35. You'll need a good hubcentric spacer !
    Jun 14 2005
    Anaheim, CA
    Get a 3-5mm hubcentric spacer and you should be fine. Suggestion would be H&R
    -Charles@VMRWheels
    Brandon @ VMR Wheels
    Apr 12 2008
    Connecticut
    Quote Originally Posted by VMRWheels View Post
    Get a 3-5mm hubcentric spacer and you should be fine. Suggestion would be Eibach.
    -Charles@VMRWheels
    Thanks guys.
    Apr 12 2008
    Connecticut
    sorry, just wanted to ask one more question. I assume that I would want to go with a set for the front and rear? The rear should match even though they clear everything, right?
    Jun 14 2005
    Anaheim, CA
    Quote Originally Posted by golovemd View Post
    Thanks guys.
    I meant to say H&R, not Eibach.
    -Charles@VMRWheels
    Apr 12 2008
    Connecticut
    -Charles@VMRWheels
    Ok, again do I need two sets? Should I order for the rear to match the front? I am waiting to hear from you guys before I order, wanna do it right the first time.
    Oct 06 2006
    South Bend, IN
    I'd do four all the way around, otherwise it may look funny.
    Jun 14 2005
    Anaheim, CA
    Well depending on what kinda look your going for... an all around aggressive look or a bull dog kind of look with the aggressive stance in front.
    -Charles@VMRWheels
    Apr 12 2008
    Connecticut
    -Charles@VMRWheels
    I'm not really going for any particular look. I just want the front tires to clear the control arms.
