Results 1 to 24 of 24
Thread: Thermal Wrap
    Established Member Two Rings clcsocal's Avatar
    May 16 2008
    '04 A4 USP, '84 928S
    Santa Clarita CA
    Question Thermal Wrap
    Getting ready to install my test pipe and wondering about the benefits of doing a thermal wrap. I'm brand new to turbos and not looking foreward the getting the cat out of my CVT 1.8T. Want to do the wrap prior if there is benefit. Any advice?
    '04 Arctic White USP 1.8T
    APR stage 1+ | Siemens 380cc | VMR TP | Clear Corners | Painted Calipers | Cupra R Lip | Euro Tails | Dension Ice Link | Apikol SMIC | Hawk HPS | K&N | Slotted & Drilled Rotors | Magnaflow | APR Snub
    "A weak list I know, but it's mine"
    USP CLUB MEMBER #112
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    Re: Thermal Wrap
    Reducing underhood temperatures. It is definitely worth it. On my car I have everything wrapped, the hot side of the turbo, manifold, and DP.
    Some fast things and some slow things
    ~Josh~
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: Thermal Wrap
    Just so you know, wrap can cause the metal to crack sooner since the wrap tends to trap moisture between the wrap and metal pipe. It is better to go with a ceramic coating.
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: Thermal Wrap
    Quote Originally Posted by mtbrider View Post
    you would reduce underhood temps...
    - Clint
    Veteran Member Four Rings jrau13's Avatar
    Mar 12 2006
    02 Mercedes ML, 04 Avant 1.8t
    Costa Mesa
    Re: Thermal Wrap
    I've heard that before so I think ill go with the ceramic coating. Mike do you know of a good place to get this done is socal for my testpipe, when I get it?
    I'll keep my money,
    My Guns, My Freedom,
    & you can keep the CHANGE
    Jul 07 2004
    socal
    Re: Thermal Wrap
    Quote Originally Posted by jrau13 View Post
    There should be a few good places in socal to get it done. I know my friend got his manifold done for his Evo so i can ask them, pretty sure its in the riverside area.
    Veteran Member Four Rings oildrpr's Avatar
    Apr 07 2007
    Huntington Beach, Cali
    Re: Thermal Wrap
    Josh... test pipe install party??? lol. i'm thinkin of gettin one too...
    Mar 12 2006
    Costa Mesa
    Re: Thermal Wrap
    Yeah I wanna get one in the next month or so. No rush really but let me know.
    I'll keep my money,
    Senior Member Two Rings [IX]'s Avatar
    Mar 09 2008
    Florida
    <<NO SIG>>
    Apr 07 2007
    Re: Thermal Wrap
    i'm lookin for a test pipe that inside a cats body.. so it looks like a cat convertor, but it's a test pipe.. just in case my hood gets popped and looked into by the boys in blue.. so as soon as i find one, at a decent price. i'm on it :)
    Mar 12 2006
    Costa Mesa
    Re: Thermal Wrap
    Fast Intentions may be able to do that for ya. If so let me know.
    I'll keep my money,
    May 16 2008
    Santa Clarita CA
    Re: Thermal Wrap
    Nice pics. What brand and supplier.
    Jul 07 2004
    socal
    Re: Thermal Wrap
    Quote Originally Posted by oildrpr View Post
    Just find a old cat that is bad and have it gutted, then just have someone install a pipe inside of it so its just a straight flow thru.
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Re: Thermal Wrap
    You can remove the heat shield off of your OEm can and put it on your test pipe.
    Apr 07 2007
    Re: Thermal Wrap
    yah, it doesn't seem to be easy to find a used cat tho.. i think i saw one on ebay, but i was still undecided i guess.. lol.
    i have my new exhaust coming in this week (AWE), i'm all set to go with Stage 1+ (either Revo or GIAC), and i'm just thinkin i should do the test pipe at the same time.....
    May 16 2008
    Santa Clarita CA
    Re: Thermal Wrap
    Well the job is done. The thermal wrap was a breeze, except that I didn't buy enough and had to do it in two pieces. My local parts house sold the wrap by the foot and they told me 6 feet would do it for the B6. It takes nearly 10 feet to do a good wrap.
    The install was pure hell. No actually the install was easy, about a half hour . . . . after 6 hours of hell trying to get the cat out. If you do this job, plan on having to cut the lower bolts, where the cat meets the excaust, off with a Dremal. The bolts are extremely un-accessable and after trying every trick from every web site(PB Blaster, impact wrenches, etc.), I ended up cutting. They were basically welded together with rust and heat. The lower O2 sensor made it extra complicated, and I couldn't get it out until the cat was cut free.
    It was all worth it in the end. There is noticably more power, and it revs to red line much quicker.
    Now all I have to do is figure out how to pass CA smog in two years.
    Veteran Member Four Rings supamannn99's Avatar
    Nov 15 2007
    Orange County, SoCal
    Re: Thermal Wrap
    just put the cat back on :D
    that's what im gonna do
    May 24 2007
    Southern California
    Re: Thermal Wrap
    Quote Originally Posted by clcsocal View Post
    same here. the cat was sooo stubborn. its took a few soak downs with PB blaster and some 5 hours(w/breaks) worth of good wacks w/ a hammer on top of a 3 foot socket extension until it finally broke loose (as i was shouting in joy). cutting would probably have been a little easier but i could quite fit the dremel up in there. oh well. i have a year left until smog testing. better enjoy every bit of it.
    Kyle
    2.0L Revo GTRS Eliminator
    Apr 07 2007
    Re: Thermal Wrap
    hmm.. so did it unbolt from the turbo pretty easily?? i'm getting a new exhaust, with a downpipe.. so if i run a TP too, i can just bolt that together before i put it into the ride... may make it easier...
    also, when you do a TP, do you use Defoulers? i may go with Revo st 1+... but i dont want any CE lights, obviously..
    and throw some pics up of the mangled cat.. and oh yah, if you're not going to keep your cat. i will take it! :)
    May 24 2007
    Southern California
    Re: Thermal Wrap
    unbolting from the turbo wasnt bad at all. 1 bolt is a tight fit but nothing an extension cant take care of. i didnt use defoulers, my codes were permanently cleared. the cat itself wasnt really mangled, just the old bolts/screws.
    Kyle
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    Re: Thermal Wrap
    another advantage to this is keeping exhaust gasses hot and movin through there.
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    May 16 2008
    Santa Clarita CA
    Re: Thermal Wrap
    I was pretty stoked for a day because my CE light didn't come on, but yesterday it finally did. Still runs great, I just need to get back into Eurocode and get it cleared. I thought about selling the cat, but should keep it if I can't find a way around smog. I have been told there is a smog test shop in Van Nuys that will submit a pass, but I have no idea it is true, or more importantly, what it will cost. I would be willing to pay well to avoid putting that cat back on.
    I was suprized it didn't make my exhaust note change much. I was hoping for a little deeper tone. Have any of you cut out your resonator and gone straight pipe? I did it on my VR6 and loved it, but I still had the cat on. I'm wondering what the combination is like. I don't want it too loud or rattly.
    Buncha motorcycles
    Memphis, TN
    Re: Thermal Wrap
    i was amazed at how much it lowered my EGTs and how much quicker the EGTs returned to normal. It used to take 5-8 minutes for my egts to return to about 400, after installing the test pipe, as long as i drive easy, its back to 400-425 inside of a minute or two
    APR Stage 2/AWE Intake
    Stage 3 Forum Advertiser Four Rings VMRSport's Avatar
    Apr 25 2008
    Irvine
    Re: Thermal Wrap
    Thermal wrap, if done improperly, could cause uneven heating of the test pipe. Might not be a big deal to some, but it could happen.
    I've also seen people use a thermal coat, to try and keep the heat from escaping into the engine bay as much as possible.
    If you check out our test pipe, we use a heat shield that has a similar look/design as the OEM car, but ours is designed to help keep the heat in, and prevent it from soaking into the rest of the engine bay.
    This box does not currently receive PM's. Please direct all inquiries to Charles (VMRWheels) or Peter (Peter@VMRWheels).
    B5/B6 Audi A4 Test Pipe w/ Heat Shield
    VMR Sport | Integrated Vent Gauge Kit
    B7 Audi A4 Test Pipe - $69.99
