Results 1 to 2 of 2
Thread: Too Much Oil?
    Senior Member Two Rings NYCS4Avant's Avatar
    Apr 23 2008
    B6 S4 Thunder Wagon
    Too Much Oil?
    So I recently checked the oil level on my B6 S4 and it appears to be above the "A" range. That is, above the grooved/dotted area on bottom portion of the dipstick. I read the owners manual and its says it may suck oil into the crankcase/ breather track. Should I go and have some oil removed? The oil was supposed to be changed when I picked up the car about 1,5xx miles ago.
    Established Member Two Rings s4for5's Avatar
    Feb 19 2005
    05 S4 Dolphin without the Fish Mouth & about every other gas powered toy a guy could want..
    Xenonville
    if
    If it's only a little bit above I wouldn't worry.
    If it's more than say 5 millimeters I would find a suction pump and pull some out.
    If yours is like most others, it will consume between 1/2 and 1 qt every 5-7k....if your lucky
