Results 1 to 7 of 7
    Veteran Member Three Rings mike's machine's Avatar
    Apr 01 2008
    Ducati M750 900SS Honda CBR600rr Ruckus
    Massachusetts
    OEM sport suspension
    will stock sport suspension make the car handle better ?
    it obviously won't be like after market ones, but how is it compare to the normal ones?
    does it lower the car a little?
    and i'm talking about C5 A6 here...
    thanks.
    Veteran Member Four Rings Gigi's Avatar
    Jan 23 2006
    2004 Audi A6 2.7T, 1999 Jeep W
    Charlotte, NC
    Re: OEM sport suspension
    it'l be a little lower and stiffer but if yuo're going to do labor,might as well go for aftermarket noes
    Have a great day, Brice
    99 Jeep TJ, 4" lift, Mikey Thompson rims & tires
    http://i157.photobucket.com/albums/t...i/photo-22.jpg
    http://i157.photobucket.com/albums/t...20TJ/Jeep2.jpg
    SOLD: 04 Blue [B]A6 2.7TStage 2 +: Many mods
    Apr 01 2008
    Massachusetts
    What's good match for springs and shocks with good price?
    Senior Member Three Rings massboykie's Avatar
    Mar 14 2008
    '16 Audi S6, '16 Audi S5 Cab.
    Natick, MA
    Quote Originally Posted by mike's machine View Post
    Hey Mike
    I've never driven in an A6 with the not sport suspension, but I think for a daily driver the stock sprt suspension works very well.
    Sport suspension: 20mm lower, shocks 40% stiffer, springs 30% stiffer, thicker swaybars front and rear.
    I must agree, that if you are going to do all this work, you might as well go aftermarket. The only benefit to stock would be price (used obviously), but getting all of these pieces in descent shape would probably be difficult also.
    Cheers
    Massboykie
    2016 Audi S5 Cab. - ECS Intake, K&N DI
    2016 Audi S6 - K&N DI, 10mm VCDS drop+12mm Spacers, Disc Italia+HPS 5.0
    Not to be forgotten...
    2016 Audi A3 2.0T, 2006 Audi A4 Avant 2.0T, 2002 Audi A6 2.7T, MKIV VR6 GTI & GLI, MKIII GLX & GL Jettas
    http://www.VAGLinks.com - 2000+ VAG Links!
    http://www.PlanetVAG.com - VAG Only Search Engine!
    Jan 23 2006
    Charlotte, NC
    if you want to retain comfort but lower and improve handling some, get Konis FSDs with Eibach springs. If you want firmer, lower top handling get koni yellows and H&R or eibachs for a little softer
    Apr 01 2008
    Massachusetts
    If you can get oem sport suspension for a little over $100, would it be worth getting it?
    Jan 23 2006
    Charlotte, NC
    shocks and springs? Sure... but I would be concerned with mileage on them/wear (Shocks) at that price. Also the car won't be low and still dive/roll a lot. I had the sport suspension on my car. I would personally try to find a used aftermarket setup to get more out of the work you'll be doing. But it is up to you and what you're looking for
