Originally Posted by
n7plus1
i took a look at the all the s4 write-ups about that, but everyone said its bi-xenon only, plus they dont have the same adjustment things...
If your ballast is on the bottom of the housing, the "O" ring replacement described for S4 housings, does not apply. If your housings have the ballast mounted on the large single housing rear cover like the S4 housings use, then the O ring fix will apply.
But regardless, make sure the covers are sealing tightly around the entire cover gasket. You can bend the retainer wire clips a little to have more pressure against the covers when installed. The Second thing is to apply a thin bead of sealant around the lens/housing joint. While the housings are being checked, make sure ALL of the moisture is dried from inside, there is water trapping areas especially in the forward bottom of the lens.
PM me for additional information.
