Results 1 to 26 of 26
    Veteran Member Four Rings Exanimas's Avatar
    Mar 09 2008
    is full of crap.
    Boston, MA
    I failed at life
    And at installing my Forge DV today. Me and my friend worked on getting those one time use clamps off for about 2 hours before just saying screw it. Tried everything. We tried getting a flathead screw driver in where the clamp ends and prying - no go. I bought a set of tin snips and tried clipping off where the clamps stick up - nope, not enough space. I even called a local shop just to inquire about the install and the guy was cool enough to tell me that he usually just uses a dremel and saws through the part that sticks up, but I wouldn't feel 100% safe doing that and currently don't have access to a dremel. What gives? This was only supposed to be a 20-30 minute install. Unfortunately, I think I'm going to end up taking it to a shop and paying the $70 to have it installed.
    Sorry, just had to rant and get it off my chest.
    For reference, here's a picture of me working on it
    -Nick
    2008 B7 A4 Avant 2.0T 6spd
    In Limbo Four Rings
    Sep 27 2006
    2005 Audi B6 1.8t Ultrasport
    New Jersey
    Re: I failed at life
    haha no worries man it takes that long if its ur first time. shit the first i almost dropped the car on me =) cause i started moving it and shaking casue i got so mad.
    Apr 08 2008
    Toronto, Canada
    Quote Originally Posted by Exanimas View Post
    HAHAHAHA, priceless pic!! Those clamps are a bitch, so I got a friend who has more patience than me to remove the clamp, don't know how, but it's done.
    2002 Crystal Blue Metallic A4 1.8T Quattro
    2004 Black Volvo S60 2.5T AWD
    Senior Member Two Rings nitelyfe's Avatar
    May 14 2007
    That truck have quattro ;)
    I can't tell if this is a joke or for real. If it's for real, I feel your pain bra. Same thing happened to me. Luckily I thought of using a cutter plier type tool. Here is an example- http://www.amazon.com/Channellock-35...0968155&sr=1-2
    Those are essential for this to be a 20-30 minute job. Replace with multi use clamps and it'll be even quicker next time.
    2003 Dolphin Gray 1.8TQ Sport
    Mods:
    K&N air filter, Hyperboost DV, Revo ECU tuned, USP front bumper, Bremu bolt down coilpacks, NGK Laser Platinum plugs, ESC Snub Nose engine mount, 18" TSW Kyalami hyper black wheels, Dual XDVD8625 in-dash video, Cobra XRS 9300 (hardwired), Ceramic Formula 1 "auto film" (tint)
    Veteran Member Four Rings GTMRS4's Avatar
    Sep 14 2006
    New York, NY
    I just used some wire cutters and just had some patients. However, I learned for the one time clamps just put the flat head screw driver underneath the pin and take rubber mallet and just give it a lite tap it should pop off.
    BetaAlphaTau # 18
    2007 Q7 4.2 Premium
    2007 997 Midnight Blue
    2005 Lotus Elise Magnetic Blue
    2004 B6 APR STGIII+ (SOLD but not forgotten)
    Senior Member Two Rings [IX]'s Avatar
    Mar 09 2008
    Florida
    The 4th picture shows the tool I used
    http://www.audizine.com/forum/showthread.php?t=143751
    <<NO SIG>>
    Mar 09 2008
    is full of crap.
    Boston, MA
    My post was serious up until the truck picture. I just thought I should give some sort of visualization to my failure.
    I think the biggest problem was both me and my friend are 6'2" and over so we both have huge hands. It was tough to get anything in there to even try and pry or clip. If it's nice out another day maybe I'll give it a second shot (since I still have my friends Rhino ramps) with a different tool or some more patience.
    -Nick
    Mar 09 2008
    Florida
    I feel you I am 6'6" and 245 lbs
    <<NO SIG>>
    Mar 09 2008
    is full of crap.
    Boston, MA
    Quote Originally Posted by [IX] View Post
    Yikes. So not only are your hands huge but your arms probably aren't too small either haha. Anyways, maybe I'll check a local hardware store for that tool nitelyfe posted up. As long as I could get it in there it would be cake.
    Oh, something I just thought of. Is it possible that the part of the clamp that sticks up is in a different position (as in rotated one way or the other around the hose) than other people's cars and mine is just harder to get it? Just a thought.
    -Nick
    Veteran Member Four Rings a4darkness's Avatar
    Dec 01 2007
    San Jose CA
    On my B5, I was having the same issues and wound up basically peeling the one-time-use clamp apart with two pairs of needle nose pliers. Not sure if that'll work for ya... but figured it was worth mentioning. Good luck.
    Buncha motorcycles
    Memphis, TN
    LMAO! i had trouble with the clamps too, they are easy to pop off once you understand how they work but its tricky in that space, since they are SS, i couldnt cut them either! i gave up, went to walmart and got a dremel, i was done 15 minutes later
    APR Stage 2/AWE Intake
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    ^^^ dremmel and cut off wheel worked great and that thing is handy, good tool to get..
    Dec 01 2007
    San Jose CA
    Side note, everyone should consider buying a Dremel. I never realized how handy it was till after I finally got one.
    May 26 2005
    CLS63tt
    Boston
    just curious what shop did u go to?
    time to take my forge out and im not looking forward to it
    Dec 06 2007
    what u can do is stick a thin needle nose into the dome shaped hole, both ends of the plier, and pull them apart making the hose clamp expand and slide them off, or take a flat head stick it in the same spot and twist it!
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Three Rings eg6siR's Avatar
    Feb 06 2008
    1993 honda civic Si, 2004 Audi
    pittsburgh pistolvania
    Quote Originally Posted by GTMRS4 View Post
    ^^ thats what i did too, flat head screwdriver and i had the whole thing done in 15 min.
    snailspeed.net
    04 1.8t 6spd dolphin grey
    "you can go fast cheap but it wont be perfect, or you can build it right and go fast, but it wont be cheap"
    Mar 09 2008
    is full of crap.
    Boston, MA
    Haha, after all the people saying they had it done in 15 I feel like a big idiot. This could be good though. Maybe I'll go pick up a dremel. About how much would one cost and any suggestions on brand/model?
    @piz - I went to a shop in Wakefield, Marc's Foreign Car. He's a pretty good guy and like I said, since he couldn't take me today he just suggested how I should do it. $70/hour isn't too bad for a guy that specializes in Audi/Mercedes either. So far I've only got my ECU tuned by him though, so I can't really say too much about him.
    -Nick
    Mar 13 2006
    2002 A4 1.8TQM
    Columbus OH
    Looks like I'm 5 minutes too late... my post was GOING to read:
    Now that you've posted up your problem, go back and try again, it'll pop off on the first try. Happens to me EVERY time. I try a simple project, get extremely frustrated, post up my problems online, go back, and BAM! done.
    I think it's the ranting gets rid of the frustration, and you can work with a clearer mind again.
    Also... I love my dremel!
    Upgraded the motor a little, brakes a little more, and suspension a lot.
    May 14 2007
    Dremel is the brand and I LOVE my 10 volt cordless. Easily top 5 tool of all time. It comes with some attachments/bits but, I recommend buying a pack of attachments too.
    Mods:
    Mar 09 2008
    is full of crap.
    Boston, MA
    Quote Originally Posted by nitelyfe View Post
    Ha, I forgot Dremel is the brand name and it's called a rotary tool haha. Thanks for all the tips guys.
    -Nick
    Veteran Member Four Rings FireWire's Avatar
    Sep 22 2007
    03 Q1.8T B6
    San Jose , CA
    id hold off on the dremel , I had the same problem when I was swapping out my dv.
    I bought a dremel and ended up never using it , a buddy of mine simply used a flat head screw driver and popped the clamps.
    + you don't really have alot of room down there to work with a dremel.
    Typ 8E 03 1.8t Quattro
    2006 600RR
    my photos
    Mar 09 2008
    Florida
    201/2" but Im not counting
    <<NO SIG>>
    Veteran Member Four Rings Dolphin18T's Avatar
    May 17 2007
    I originally tried to use cutters, but gave up soon and went straight for the Dremel. The screwdriver method seems to work best if you can get the right angle on them though. I just did a TIP install using the screwdriver method and it only took about an hour and a half. I do remember those DV ones being a PITA though. Good luck.
    -Ryan
    Maestro Tuned
    Now with slushbox-delete mod!
    Veteran Member Four Rings HeHateMe's Avatar
    Apr 05 2005
    lost wages, nv
    LOL that is one of the funnier thread titles I've seen.
    <old school>
    --giacfxk03-siemensinjectors-milltekexhaust-ofestage4clutch-eibachprokit-stratmosphereshortshift--
    abracadabra homes http://www.audizine.com/gallery/data...une_06_142.jpg
    Veteran Member Four Rings quat's Avatar
    Apr 06 2007
    A4 Quattro 1.8T, H-D VRSCA
    Pittsburgh
    you know what they say about guys with big hands...
    ...they wear big gloves.
    Veteran Member Four Rings SeKKeY's Avatar
    Mar 06 2005
    MKVI GTI (dd), DTM S4, B6 USP (sold), B5 1.8T (RIP)
    San Jose, CA
    it took me 2 hours to get off my stock clamps with pliers, screwdrivers, and finally a dremel. youre not the only one that failed
    USP CLUB MEMBER #10
    Stage 2++++++++ JHM B7 S4
