Results 1 to 3 of 3
    Senior Member Two Rings jza80's Avatar
    Dec 13 2006
    TTS Conv, R33 Skyline GTR, Suzuki B-King
    South OC, CA
    How much front drop and stay in OEM camber spec limits?
    I'm thinking about a c/o setup for my 06 S4, but I don't want to have a lot of negative front camber and deal with all the issues that comes from that. Is there a known limit to the amount of drop that is possible while staying in the spec range for camber? When I dropped my other car 30mm, the camber changed from about 0.6deg neg to 1.8deg neg and I had to fit adjustable front upper links to dial it out. It was tramlining pretty bad with 1.8deg, even though this one is a hardcore performance car it still was unacceptable. I don't want to create the same issues on the S4, which does not have adjustment and no decent aftermarket adj. front link/arm availability, apparently.
    I'm only looking for a slight drop for the S4, maybe 1/3 - 1/2 inch, I really just want to make the look a bit more aggressive and also firm up the handling a bit. I'm thinking KW's.
    Anyone have a similar (slight) drop and can comment?
    Jan 16 2007
    Wetzlar
    Re: How much front drop and stay in OEM camber spec limits?
    would like to know the same
    Senior Member Two Rings Fizikal S4Avant's Avatar
    Aug 03 2008
    2010 GT3, 2013 S4, 2018 Q5, 2020 Model 3
    Mill Valley, CA
    I concur
