Results 1 to 7 of 7
    Veteran Member Four Rings lnferno's Avatar
    Oct 14 2006
    Rocky Mountains
    AWE OTS Stage III Logs (6200 ft altitude)
    Environmental Conditions:
    Altitude: 6200'
    Temp: 51 Degrees fahrenheit
    Humidity: ~50%
    Octane: 91 pump gas
    MODS:
    * AWE K04 turbos (RS4 Turbos)
    * AWE Full Stage 3 Fueling Kit
    * AWE downpipes
    * AWE Twin 2 exhaust
    * AWE Intercoolers
    * APR Bipipe
    * EVO air Intake
    * GIAC Stage 3 software
    * Samco hoses
    * New By pass valves
    * RS4 clutch
    * RS4 motor mounts
    * RS4 shift knob
    * JHM short shifter
    * AWE DTS
    Please note that these were done at 6200' elevation. I don't have the AWE Stage III High Altitude file/Software yet -- I'm going to get tuned here shortly and will get that file. These logs were done with OTS AWE/GIAC Stage III software. Obviously, I'm in dire need of the high altitude software/custom tune. Don't get me wrong -- the car feels very strong, but it is running rich. I'm just in need of a tune. These logs are the "before". After I get tuned, I'll post up the "after" logs.
    All comments are welcome, but I'm particularly interested in the knock voltage and O2 voltage readings. I'm thinking that my 02 sensors may be on there way out? Everyone's feedback is appreciated. Also, if I left any details out, please let me know. This is my first time posting up these types of logs, so my apologies if I left any details out -- speak up if anything else is needed for me to receive the proper feedback from you. Thanks in advance for taking a look.
    Also, I did have a little heat soak going on in the first run. I should have let my car cool down a little better before that first run, and as such, the IATs were a little higher on that first run compared to the rest of the runs.
    Current: 2021 Audi SQ7
    Past: 2014 Audi RS7 Stage 2 (quickest in Colorado) | 2014 Audi S6 Stage 1 | 2011 Audi A6 Suzuka Grey Avant (1 of 1) Stage 2 | 2006 Porsche Cayenne Turbo S | 2001 Audi S4 - Stage 3+ | 2006 VW Toureg V8 | 2006 A4 Avant - Stage 1 | 2006 Audi A4 - K04 | 2001 Audi S4 - Stage 2
    Veteran Member Three Rings audiwop's Avatar
    Dec 11 2006
    2007 Audi RS4, 2010 Ford SVT Raptor, Toyota Tundra, VW Treg,Ducati Hypermotard 1100S
    Orange County,CA
    Re: AWE OTS Stage III Logs (6200 ft altitude)
    Just curious, what size injectors do you have?
    Oct 14 2006
    Rocky Mountains
    Quote Originally Posted by audiwop View Post
    Green Tops 42#
    Veteran Member Four Rings KompMan420's Avatar
    Sep 04 2005
    2001.5 Audi S4
    Tampa, Florida
    From looking at all of this, the most important question I have is do you have a full size pic of your avatar?
    SOLD - 2001.5 Audi S4 Twin Turbo ~ 450hp
    Mods - AWE/GIAC Stage 3 | AWE Intercoolers | STaSIS Coilovers | RS4 Clutch | 3" Borla Cat-Back | ASP DTS | JHM Solid Axles | "Piggie" downpipes | Neuspeed SS | AWE Pedals | IceLink for iPod | 710n DVs | M3 Spoiler | LM Reps 18x8.5 Satin Black w/red Time Attack
    www.NJSRealty.com
    Apr 05 2007
    Quote Originally Posted by KompMan420 View Post
    2nd! Her curves > your timing curve
    Feb 17 2004
    Sterling, VA
    I'm surprised that you have IATs that high with upgraded ICs. You really have alot of CF in the mid-to-high RPM range. That AWE file must be requesting a lot of timing.
    I also don't find your car to be running rich at all. The highest O2 voltages shown are .88v and that's at redline. You could actually use a little more fuel in the mid-range area.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Oct 14 2006
    Rocky Mountains
    ^ Thanks for the feedback. Yeah, I misinterpreted the A/F. Although I do know that most people up here at this elevation usually do have higher IATs than what you'd get closer to sea-level. The car has to work harder than a car at sea-level for the boost that it's requesting. I think that's a big part of the problem. I can't wait to get this sucker tuned as I'm sure there's a lot of room for improvement.
