Results 1 to 16 of 16
Thread: Fog Mod
    Registered Member Two Rings peregrine's Avatar
    Jan 09 2008
    2005.5 2.0T Quattro
    Fog Mod
    http://www.audizine.com/forum/showth...ght=longer+fog
    I just did this in just about the amount of time psycotic one posted in both my b6 and b7. Something so little makes me so happy. I was driving in the mountains over the weekend and the fog was ridiculous. The xenons were on along with the fogs and I could not see a damn thing. I'm hoping next time. I'll try just having the fogs on next time and hopefully it'll cut through the fog better.
    Mar 13 2006
    2002 A4 1.8TQM
    Columbus OH
    Re: Fog Mod
    tee hee... my 2002 does this from the factory. :P
    Upgraded the motor a little, brakes a little more, and suspension a lot.
    Jan 09 2008
    2005.5 2.0T Quattro
    Re: Fog Mod
    Quote Originally Posted by Mikef5000 View Post
    Yeah, I know I did the vag mod but on the 2003+ the fogs stay on all the time as drl's and didn't like that. This simple mod by psycotic one by just wrapping some copper over the to pins and putting some tape on one of the pins was just too easy and now my fogs run independently. I missed that because I had it on my C5.
    Dec 06 2007
    Re: Fog Mod
    ^^did this a while back and i love it i drive at night with just fogs on sometimes because they're strong enough, but i think u should get yellow fogs before u do canyons because halogen fogs do nothing!
    -Kirk
    BetaAlphaTau Member #58
    Registered Member Three Rings RÖTSCHNEL's Avatar
    2002 a4 1.8TQ M5
    Burlington, VT / NJ
    Re: Fog Mod
    not mine?
    -Brian-
    2002 Amulet A4 1.8TQ MT5
    Want custom stenciled skateboard decks for only $30??? PM me.
    Veteran Member Four Rings J-jizzle's Avatar
    Aug 28 2007
    Tools, Parts and the GTI beater
    Birmingham Alabama (Tennessee)
    Re: Fog Mod
    Dang didnt even know a write up like this existed. I just got my vag-com cable (which Im still trying to get working) to do the fog mod. But Im goin to go out and do this instead,here in a few.
    And do "yellow" fogs really put out more light, then just regular halogens? What about if you modded your fogs like this http://www.audizine.com/forum/showthread.php?t=84932 , would the yellow fogs still be better. (visual preference aside)
    Dec 06 2007
    Re: Fog Mod
    ^^yes the yellow color cuts through fog much better, hence why all old cars like benzes had yellow fogs, and if u buy the ones off ebay they are 80W but only draw 55W which is much brighter!
    -Kirk
    Aug 28 2007
    Re: Fog Mod
    Quote Originally Posted by AudiA4Turbo22 View Post
    Ok thanks. And damn it Just tried the fog mod mod but it didnt work. I didnt see the first time where you still have to vag the car. Guess I get to play with this vag some more.
    Dec 06 2007
    Re: Fog Mod
    ^^make sure urs is an 02 because mine was produced in 02 but is an 03 model and well i had to cut some wires!
    -Kirk
    Aug 28 2007
    Re: Fog Mod
    Mine is an 02. If it isnt I missed something somewhere when I bought it. Anyway do you know (or anyone) where I can find a DIY on the RTW vag recoding. I finally got my Vag-com interface to work and just did the remote windows. Now if I can just do these lights I will be set.
    Jun 30 2007
    A4, S4
    Orange County, CA
    Re: Fog Mod
    if you dont have the auto headlight feature, can you install the module that will allow you to have it?
    Dec 06 2007
    Re: Fog Mod
    ^^what module, and anyways yes if u go to Ross-tech and search for B6 every mod is listed right there!
    -Kirk
    Jun 30 2007
    A4, S4
    Orange County, CA
    Re: Fog Mod
    ^^you know how some of the 04 USPs have that coming home feature right near the headlight switch? that allows for you to keep your fogs on or something like that? i wanted that option.
    Dec 06 2007
    Re: Fog Mod
    ^^oh i C! my bad, ya those only work if u have the switch and the sensor that goes on ur dash, which basically detects the absence of light and turns them on when u unlock and stuff!
    -Kirk
    Jun 30 2007
    A4, S4
    Orange County, CA
    Re: Fog Mod
    ^^has anyone install this separately and made it work? is it possible? whats the other mod youre talking about?
    Dec 06 2007
    Re: Fog Mod
    ^^i read ur post wrong i was talking about the fog mod, anyways yes it's possible if u can pull the setup off of someone's car in the junk yard then u can use the setup!
    -Kirk
