sad!
i was practicing launching for this season in a parkin lot. and dropped the clutch at ~5500 rpm's, tires spun, took off like a bat out of hell and went to redline-ish. and pressed in the clutchand took it out of 1st gear and into neutral(like an idiot!). heard nothing from inside, but stopped and tried to reverse, but couldn't. couldn't get into any gear at all.
symptoms:
-wont go, even close, into any gear when car is on.
-when the car is off, it will go into 2,3,4, and 1st barely.
-putting the car in 2nd gear while off, i start the car with clutch in and the car lunges forward softly and dies.
-spaced off looking for any hydro fluid under the car. so im not sure if it was leaking any
car's at my brother's shop and well take a look at it tomorrow. at first i thought i bent the shift linkage, like the main shift fork. but starting the car in gear and having it lunge and die, is not a good sign im affraid..
what do you guys think?
