Results 1 to 40 of 43
    Senior Member Two Rings Switchblind360's Avatar
    Feb 26 2006
    '01 allroad 2.7T TIP, '95.5 S6, '91 200
    Boise
    19oz Carbon Fiber Experiment. Opinions???
    Hey guys. I ordered some 19oz 2x2 Twill carbon Fiber to see if its possible to use and how good it looks. This is the same fabric that was used in the B5 RS4 trim.
    Tell me, do you like? Can you tell the difference from the standard 6oz or 12oz fabrics that are used for most CF parts, hoods, trunks, trim, mirrors, etc?
    '00 Audi A6 2.7TM
    HB Nefmoto Stage 3
    '91 Audi 200 QTM 20v
    TAP Stage I
    '01 Audi allroad 2.7T TIP
    Homestyle Nefmoto Stage II, 402 Mod
    '95.5 S6 QTM 20v
    034 Stage I
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: 19oz Carbon Fiber Experiment. Opinions???
    I like it. The stuff I really liked, IIRC, was called "H8". It's thick and used mostly for structural parts.
    Established Member Two Rings 1hotA4's Avatar
    Apr 25 2008
    My little 2001 A4 2.0T
    Atlanta, Ga
    the Thickness of the Twell is what you see. Its not a huge difference. From my understanding on Carbon Fiber, the higher the OZ. or weight the more rigid you need the product to be. Are those the parts you made with it or the factory RS4 parts?
    BetaAlphaTau Member #37
    "Opinions are like Assholes, everyone has one!"
    Veteran Member Three Rings Grangalan's Avatar
    Sep 27 2007
    Stage III 2001.5 S4
    Clearwater, FL
    Looks pretty good :) Got anything heat resistant?
    --Black 2001.5 -S4- 10secS4 Tuned
    Veteran Member Four Rings gotaudi's Avatar
    Jan 26 2006
    2001 A4 1.8T
    Socal
    heat resistant would be all in the resin so all he has to do is change the resin type in order to have heat resistant properties. I am sure the resin he uses it pretty heat resistant you dont want his resin melting on a hot summer day.
    BetaAlphaTau Member#22
    Mods:
    GTRS Elim+Unitronics+ATP high flow mani+Neuspeed TIP+Custom intake+Labree HFC+Apexi AVC-R+APR Exhaust+Precision FMIC+SB OFE Stage 4+034 street density motor mounts+Purems snub+S4 Front bumper+18" BBS RC rims+Neuspeed race springs+Bilstein shocks+Nuespeed sways=
    73 74 69 6c 6c 20 73 6c 6f 77 <--- Look it up
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by Grangalan View Post
    You plan on doing an overlay on your exhaust?
    Veteran Member Three Rings dmaize's Avatar
    Jan 26 2007
    Saint Paul
    hey that looks great. how hard is it to do the trim, i have done fiberglass before but new carbon fiber.
    why didn't i buy a rs4 gill when they were $60
    Feb 26 2006
    Boise
    Quote Originally Posted by dmaize View Post
    There you go. Carbon Fiber is just like fiberglass with the exception being that you are showcasing the fiber instead of hiding it.
    '00 Audi A6 2.7TM
    HB Nefmoto Stage 3
    TAP Stage I
    '95.5 S6 QTM 20v
    034 Stage I
    Veteran Member Four Rings Mawhitey's Avatar
    Jan 20 2005
    99 AJL TQS
    UK
    How hard is that to do? Do you have any tips as i like that look, i already have the CF beltline, but the hazard trim etc would finish it
    -Mark -
    .2008cc Stroker, K04064, ME7.5, Miltek, and other goodies
    My k04064 , ME3 DBC to ME7.5 DBW build thread
    Veteran Member Four Rings fred2ka4's Avatar
    Nov 26 2005
    Audi A4, Honda Pilot
    NM
    Quote Originally Posted by Mawhitey View Post
    There is a group buy going on right now that you can probably get in on to get the rest of the pieces to finish off you interior trim. Check the GB section.
    BetaAlphaTau member #18
    2000 Audi A4 w/ APR stage III & ...
    APR // GReddy // RACETEC // Bilstein // IForged // ECS Tuning // STaSIS // Neuspeed // H&R //
    And a whole bunch of other stuff ...
    http://i78.photobucket.com/albums/j9...4/fredscar.jpg
    Feb 26 2006
    Boise
    There is plenty of information out there in order for you to do it yourself. The actual Carbon Fiber, resin, and clearcote isn't that expensive. IF you are handy and already have most of the tools for it in the garage you are set for a fun project. The biggest thing is that it takes a lot of time and patience, and order extra fabric because it may take two or three times to get it right.
    '00 Audi A6 2.7TM
    HB Nefmoto Stage 3
    TAP Stage I
    '95.5 S6 QTM 20v
    034 Stage I
    In, Out and Around...
    check your email and pm.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Quote Originally Posted by Switchblind360 View Post
    It is a lot like paper mache' in 1st grade. You wet it and lay it on there. If you are looking for a perfect finish it is still pretty easy. A basic vac bag setup with soaker and peel plys will almost always have a perfect finish. If not, it can be sanded, wet sanded, and glossed like a paint job. The real trick is getting the weave lined up straight without any kinks, bends, or other imperfections. This is quite easy if care is taken to cut the raw material straight and to leave consistent gaps. In other words, if you are doing a piece of 1.5" wide trim you cut the material to 2.5" and leave and even 1/2" hanging over each side. Wet the substrate first, lay the carbon out and line it up, fold it over the back, bag it. There are a few steps left out but they are also simple and everything you've ever wanted to know is on various composite construction forums. Most that tinker with this stuff at home find it easier to deal with than welding or forming metals or dealing with wood.
    For the trim another option is carbon fiber tape. It comes in rolls like masking tape and has finished edges that won't unravel. It is the perfect width for our trim and very easy to work with. It is still as much an art as a skill so practice on a few pieces of wood first.
    http://www.jamestowndistributors.com...map2&catId=522
    Jim
    I Do Werk.
    Senior Member Three Rings theskuh's Avatar
    Jan 31 2007
    001.8tq 04_element
    northern vermont
    Are you (is he) just going over the top of the current trim as a mold? then bagging.
    Sep 23 2007
    where do you buy this material?
    Jan 31 2007
    001.8tq 04_element
    northern vermont
    You can buy fiber all over the web. I use Raka epoxies. http://www.raka.com/
    I haven't bought fiber or cloth in a while.
    Sep 23 2007
    [QUOTE]You can buy fiber all over the web. I use Raka epoxies. http://www.raka.com/
    I haven't bought fiber or cloth in a while./QUOTE]
    would the tape that they sell work or would it just look like shit ??
    Mar 09 2004
    nw michigan.
    Woven tapes would work. Request samples before buying since quality and weaves can vary.
    You can also get soft tubes that resemble finger puzzles. We used these at Nuke Proof for our carbon center Atom Bomb hubs. I've got a piece at home that could wrap a basketball or be pulled down to about 4" diameter x 18" long. We used very thin wall aluminum cores about 6' long and then wrapped them and cut them to length after curing.
    Just search google for composite supply, carbon fiber supply, or composite forums. I like West Systems for material and resin/hardener.
    Jim
    I Do Werk.
    Veteran Member Four Rings le91688's Avatar
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    Saw the group buy and cant justify 800$ for cf trim.
    Mar 09 2004
    nw michigan.
    Then make it yourself. It is a lot of money for pretty plastic.
    Jim
    I Do Werk.
    Senior Member Two Rings coyote's Avatar
    Jun 07 2005
    Jacksonville, FL
    That's what I did. I made my own.
    If anyone is interested I can make more at a fair price.
    Senior Member Three Rings silverman's Avatar
    Sep 27 2008
    '98 A4 1.8tqm. Bilstein pss9.
    Hartford, CT.
    what's a fair price? :)
    Veteran Member Four Rings Tifun's Avatar
    Jun 21 2007
    99.5 A4, 08 Mazda3
    Indianapolis Indiana
    $100 is fair if you ask me.
    Veteran Member Three Rings discontained's Avatar
    Jul 09 2007
    '01 A4 1.8t
    GA
    coyote - Would you be willing to do the actuall door handles? Where the window switches are? LMK
    Jun 07 2005
    Jacksonville, FL
    I would be willing to do the trim pieces that I did again. If anyone is interested PM me.
    Oct 06 2004
    Minnesota
    Sent you a PM Coyote
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Jun 07 2005
    Jacksonville, FL
    All PM's responded to.
    Veteran Member Four Rings audiFUEGO's Avatar
    Jul 17 2007
    2001.5 A4 1.8t QM
    Boca Raton, FL
    Honestly, you can charge a "fair" price for something like this and still make alot of money since I dont think theres one audi owner that doesn't want CF trim.
    If you're good at it and have the extra time go for it... I'd do it if I knew how...
    Active Member Three Rings AP-Specialties's Avatar
    Mar 15 2008
    A few Audis
    Independence, MN
    Quote Originally Posted by audiFUEGO View Post
    Definitely. Fair priced products will always sell
    A&P Auto Specialties, LLC • 1960 County Road 90, Suite 100 • Independence MN 55359
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Quote Originally Posted by Tifun View Post
    For what? CF Trim? If so you are smoking something, the time alone is worth more than that when all said and done even if DIY'ing.
    Mar 15 2008
    A few Audis
    Independence, MN
    Quote Originally Posted by bassed View Post
    And the bare oem trim is worth more that that alone
    Jul 07 2004
    socal
    Wait till they try to buy the material which will cost about that before any work is started. Some people seem to think CF is cheap.
    Jul 07 2004
    socal
    Here, you can be a pro too.
    Jul 17 2007
    2001.5 A4 1.8t QM
    Boca Raton, FL
    sweet... thanks.
    Jul 07 2004
    socal
    sweet... thanks.
    Now to just make a huge mold of my car, get a huge vacuum bag and I will be all set to make a CF B5 shell.
    Oct 06 2004
    Minnesota
    Tube frame that bitch and run 8's
    Instagram r_michals
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    Alright then, how about the fair price of $105?
    It's looking great OP.
    Jul 17 2007
    2001.5 A4 1.8t QM
    Boca Raton, FL
    If I smoke a few bowls anything's possible...
    Jul 07 2004
    socal
    Quote Originally Posted by A4Rob View Post
    LOL, only if I had the money.
    I will be gunning for 9's in 2009. Car should be coming home very soon from having the cage done.
    Q7, Q7, F-type manual
    Quote Originally Posted by onemoremile View Post
    off topic, but you worked at nuke proof? i have those hubs from way back in the day!
