Results 1 to 13 of 13
    Veteran Member Four Rings blkrhyno's Avatar
    Mar 24 2008
    2004 audi a6 2.7T 2005 Nissan
    Brooklyn, New York
    Veteran Member Four Rings audirs's Avatar
    Mar 22 2005
    Kitchener, Ontario
    Re: My clear corner mod 04 s-line
    hella clean
    did u take apart the headlight to do yours? i did mine by popping the reflector out of place through the blinker bulb socket, then unscrewed the projector lens and wiggled the housing until it fell out. either way it looks nice
    Q5 3.0T S-line
    VW Tiguan R-Line
    A6 2.7T AWE Stage 3
    Coupe Quattro
    Senior Member Two Rings Asix's Avatar
    Jan 25 2008
    Audi S5
    Bellevue, WA
    nice! how long did it take you?
    Established Member Two Rings Digga's Avatar
    Jun 18 2007
    FL
    Quote Originally Posted by audirs View Post
    hella clean
    Good idea, I am terrifed of taking the headlight apart
    Current
    FOR SALE
    2013 BMW 335i M Sport
    MPE/Dinan springs/Rotiform
    http://f30.bimmerpost.com/forums/sho...d.php?t=998376
    Former
    04' A6 2.7T ~APR 93 OCT Tuned
    -APR R1 DV's, Eibach Sportlines, RS6 lip spoiler
    Senior Member Three Rings massboykie's Avatar
    Mar 14 2008
    '16 Audi S6, '16 Audi S5 Cab.
    Natick, MA
    Quote Originally Posted by blkrhyno View Post
    Here are some pics of my clear corner mod. Tell me what you guys think.
    Looks great...
    Did you "bake the light" or do the "break apart" method?
    I've been meaning to do this myself, but I just cannot seem to get "balls" to do it..
    Cheers
    Massboykie
    2016 Audi S5 Cab. - ECS Intake, K&N DI
    2016 Audi S6 - K&N DI, 10mm VCDS drop+12mm Spacers, Disc Italia+HPS 5.0
    Not to be forgotten...
    2016 Audi A3 2.0T, 2006 Audi A4 Avant 2.0T, 2002 Audi A6 2.7T, MKIV VR6 GTI & GLI, MKIII GLX & GL Jettas
    http://www.VAGLinks.com - 2000+ VAG Links!
    http://www.PlanetVAG.com - VAG Only Search Engine!
    Mar 24 2008
    Brooklyn, New York
    I did not bake it, I used the break apart method and it wasn't as easy as it seems in the DIY mod I found on audiworld. My headlight is slightly bigger than the one in mod and it took me about 5 hours to complete. I didn't take apart the bumper and they is a fouth torx screw that is not mention in the mod. Anyway I'm pretty happy with the results.
    Mar 22 2005
    Kitchener, Ontario
    Quote Originally Posted by Digga View Post
    yea me too, i didnt really want to bake it or anything. its pretty easy if u remove the headlight from the car. takes about 5 mins after the headlight is removed
    Q5 3.0T S-line
    VW Tiguan R-Line
    A6 2.7T AWE Stage 3
    Coupe Quattro
    Mar 24 2008
    Brooklyn, New York
    I did remove the headlights and I thought of removing the projector housing but it had some nuts that I couldn't reach. Audirs do your lights have the HIDs on them?
    Mar 22 2005
    Kitchener, Ontario
    yea they do. couple of the nuts were kinda hard to get at. i used a socket wrench with a thin extension to get to it. i couldnt get the lens out of the housing for some reason, so i just moved it to the side and wiggled lol
    Q5 3.0T S-line
    VW Tiguan R-Line
    A6 2.7T AWE Stage 3
    Coupe Quattro
    Jan 25 2008
    Audi S5
    Bellevue, WA
    i did the headlight take apart route. I painted my housings black. The DIY link is in my sig.
    Mar 24 2008
    Brooklyn, New York
    Asix, this off the subject but where did you get your exhust tips? Or is that a completely new setup?
    Jan 25 2008
    Audi S5
    Bellevue, WA
    I got my exhaust done at this small hole-in-the wall exhaust shop in Bellevue, Washington. They are magnaflow tips and i also got a resonator. Not sure the exact part number...but it sure does sound pretty beefy with the 2.7T
    Mar 24 2008
    Brooklyn, New York
    Thanx Asix, it looks really good, I'm going to try to accomplish that look
