Results 1 to 19 of 19
Thread: Forge 004
    Mar 31 2008
    Woonsocket, Rhode Island
    Forge 004
    Hey Everyone,
    I was thinking about going with the Forge 004 BOV I have done alot of research on multiple forums and have come to the conclusion that If I run this valve, I should not run into any problems with CEL's which was my primary concern in the first place. My question to everybody is why on ECS Tuning do they not advertise the Forge 004 in the Audi A4 B6 section? I found it in the Mark IV GTI 1.8T section. I also found it interesting that the B6 A4 was not on their applications chart. Will the install kit that comes with it off of ECS for the GTI 1.8T also work for the B6 A4 1.8T? Thank you all in advance for all of your help
    Veteran Member Four Rings FromS60toB61.8t's Avatar
    Aug 26 2007
    07 Fahrenheit GTi, 09 S8, 17 GSW S 4-Motion, 19 S4 Black Optics
    Re: Forge 004
    Quote Originally Posted by A4 Boost View Post
    Hey Everyone,
    not really much needed to be installed, just the bov and 2 clamps.
    i have the forge 004 and its nice but i have to drive on an unplugged MAF becuase the car shuts off with it if i dont
    Sep 02 2005
    Montreal
    Re: Forge 004
    Quote Originally Posted by FromS60toB61.8t View Post
    lol that's not right.
    Aug 26 2007
    Re: Forge 004
    ^ yea ik its because i have a spring in it from a BT setup and its letting off too much boost and making hella lot of back pressure so a temp fix of unplugged MAF is just the trick and yea ik it gives me a CEL but i already have 1 from my TP so its all good haha
    Veteran Member Three Rings Casius's Avatar
    Aug 14 2007
    Ottawa, ON, CA
    Re: Forge 004
    YA that'll give you a CEL, these cars don't like BOVs
    Aug 26 2007
    Re: Forge 004
    indeed, imgoing to try out a different one soon, ill let you guys know how it is, its adjustable
    Veteran Member Four Rings rxrep's Avatar
    Feb 28 2006
    has nothing in it but memories.
    Pittsburgh-Philly
    Re: Forge 004
    Ran 004 from stage 1+ through first part of stage 3+ and not one problem, ever. I just don't like the ricey noise any more.
    My 2004.5 APR Stage 3+ is SOLD
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Re: Forge 004
    I've been running one for about 5 months now... I was running rich at the beginning but still have no CEL, at least yet :)))
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    Re: Forge 004
    YOu will also need a 1" plug
    Veteran Member Three Rings AudiBama's Avatar
    Apr 27 2008
    2003 A4 1.8T
    Birmingham, Alabama
    Re: Forge 004
    Quote Originally Posted by aaaudiprotein View Post
    a what?
    explain?
    edit nevermind i found it....
    what about a Forge Splitter?
    I like the R1 but it doesnt have enough sound...should i get an intake first or go with a splitter or 004 and just use the R1 when i'm worried about performance?
    2003 A4 1.8T
    APR K04, APR Snub Mount, Forge 008 DV, Custom Magnaflow Exhaust, 034 Motorsport Catless Downpipe, K&N, VHT, Hitachi "e" Style Coilpacks, 6000k HIDs, CC Mod, Neuspeed Race Springs, Bilstein, Southbend Stage 2 Endurance Clutch, Lightweight Flywheel, Valentine 1, Driver Mod.
    Feb 28 2006
    Pittsburgh-Philly
    Re: Forge 004
    ^^^ A DV recircs spent air back to the turbo inlet pipe. A BOV like the 004 sends it out in to the atmosphere. So, since you aren't using the hose connected back to the TIP when you use the 004, you need to plug it. Hence, the 1" plug.
    And don't buy in to the "R1 for performance" hype. I'd bet cash no one but a computer notices the minute difference of a diaphram valve over a spring/piston one.
    Apr 27 2008
    2003 A4 1.8T
    Birmingham, Alabama
    Re: Forge 004
    Quote Originally Posted by rxrep View Post
    ^^^ A DV recircs spent air back to the turbo inlet pipe. A BOV send it out in to the atmosphere. So, since you aren't using the hose connected back to the TIP when you use the 004, you need to plug it. Hence, the 1" plug.
    i know...found that out via some research....any input for my other question?
    2003 A4 1.8T
    Feb 28 2006
    Pittsburgh-Philly
    Re: Forge 004
    I don't know anything about the splitter, but Forge products are good and bullet-proof, so I guess it would work well. Theory being that you can control some air to recirc back. My only thought is that if someone wants that BOV woosh between shifts, they'll end up setting the splitter to full blow-off anyhow, so might as well go with 004.
    For me, I switched to the 007. Still makes noise enough to hear it, but isn't loud enough for every high school kid within a mile to come running with that stupid "He's got a mad turbo, yo" grin on their face.
    The R1 is just hype IMHO. And I'm an APR fanboi. They could never sucker me in and with all the problems the things have had, I'm glad I didn't fall for it.
    I'd bet the same car as me with an R1 is not pulling any faster times than mine with a forge. And forges don't moo..
    Veteran Member Four Rings jcg05c's Avatar
    Jun 07 2007
    350z
    orlando
    Re: Forge 004
    ^ ive only heard problems about the r1
    19in Privat Netz 10mm front/17.5mm rear
    Apr 1+
    TurboSmart Bov/Dv
    Roof Spoiler
    Jeff Lee Test Pipe
    NS Boost Gauge
    Apr 27 2008
    2003 A4 1.8T
    Birmingham, Alabama
    Re: Forge 004
    Mine doesn't moo....i just got the freshest batch of them (now that they are built out of house) and I've had no problems with it...the sound is actually really good...just quiet w/ stock airbox..
    and APR stands behind their products...and I'm good friends with 3 people that work at APR in auburn...and i'm a short drive away so APR works out best for me...
    Yeah I guess I'll just go with the 004 if i can find one!
    2003 A4 1.8T
    Feb 28 2006
    Pittsburgh-Philly
    Re: Forge 004
    Quote Originally Posted by AudiBama View Post
    They stand behind them so they won't get hit by all the stuff people throw at them, lol.
    I've never had a problem with APR, but many on this forum have.
    Needless to say, if you have a broken part, they generally require you to send it back at your expense until they send you out a new/fixed one.
    That means down time for your car.
    Luckily I've not had anything break. But there is no shortage of people on the forums bashing APR's version of "standing behind their products".
    /threadjack
    Apr 27 2008
    2003 A4 1.8T
    Birmingham, Alabama
    Re: Forge 004
    So I'm gonna order the 004 and the plug in about an hour so if anyone has any objections....let me know...
    i have the R1 for when i need "performance"
    2003 A4 1.8T
    Apr 27 2008
    2003 A4 1.8T
    Birmingham, Alabama
    Re: Forge 004
    I decided to go with the Forge Splittr we'll see how it goes!
    2003 A4 1.8T
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Re: Forge 004
    yeah lets take all that charged air from the turbo and blow it back into the atmosphere instead of recirculating it back into the turbo to get quicker spool and make MORE POWER. BOV's are a complete waste of money on this car. Get a DV and be done with it.
