Results 1 to 4 of 4
    Veteran Member Four Rings coowhip's Avatar
    May 11 2008
    Columbus, OH
    Aftermarket stereo hookup Bose system
    I put the harness all together with the panasonic head unit tonight that has pre-out rear and fronts on the head unit and plugged in the harness and the stereo wont turn on. Is there a signal wire i'm missing to turn this thing on or what. I believe its a METRA harness. 2002 Audi A4 Quattro. its not the 25 pin harness either...2 separate harnesses, one for power and such and the other is for speaker connections...please help ASAP...
    Mike
    Veteran Member Three Rings Dirty's Avatar
    Feb 07 2008
    05 A4 1.8T 6spd Quattro
    Orlando, FL
    Re: Aftermarket stereo hookup Bose system
    You need to run a power constant.
    15 S6 4.0T Quattro
    DS1 stg1//B.E. TCU Tune
    S4 Door Blades//CC'd S4 Bi-Xenon//AWE Boost Gauge//RS4 Rear Sway Bar//K&N filter//Forge 007 DV//12" Audibahn sub-1500w//ATP 3" TP//Hitachi "E" coil packs//Revo Stage 2//FMIC & PS cooler//S6 LED's//RS style fog grills//Hawk HPS Pads//Tein SS Coilovers//19x10 et35f/et25r Rotifrom MIA's//Falken 235/35
    Veteran Member Four Rings cruzin210's Avatar
    Dec 28 2005
    Former: B6 A4 1.8TQM
    Palo Alto
    he has a power constant. You need to run an ACC wire that only gets power when the ignition is on. Most aftermarket headunits will need this to operate. And by the way, that metra harness is almost worthless. I bought it and am only using it to get power to the headunit. I wired ground directly to the battery and the ACC wire is tapping the fuse for the sunroof. Since the stock radio gets power at all times (even when the car is off) it is no good as an ACC wire.
    Black and Silver...thats it
    Quote By rds0000:
    "I actually prefer that this little t**l speaks this way, because in an otherwise anonymous environment, it really helps paint a nice picture of who is spewing this nonsense"
    May 11 2008
    Columbus, OH
    ahhh...nice, thanks guys! All is good! There was already a wire run from the last owner. Sweet!
