Results 1 to 15 of 15
    Jan 11 2008
    UK
    how do you chnage oil filter?
    hi how do you change the oil filter ? any pics or guides would be helpful thanx!
    Registered Member Two Rings quattro2003's Avatar
    Sep 29 2007
    2003 A4 1.8T Quattro
    Pittsburgh, PA
    Re: how do you chnage oil filter?
    I know some people change it from up top, but i change mine from under the car so i don't make as much of a mess. It's very easy. I just use a strap wrench i bought from pep boys and loosen it, then do the rest by hand.
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Lefty Loosy, Righty Tighty.
    -Sami-
    Registered Member Four Rings audipotential's Avatar
    Sep 24 2007
    Woodbridge, Ontario
    Quote Originally Posted by POPS11 View Post
    go to a4mods.com and youll find it
    Senior Member Three Rings jessefrank's Avatar
    Jan 09 2006
    Q7.Prestige.S-line.Pkg.2
    Rapid.City
    I put a milk jug (or similar) that is cut in half under the filter. It is a bit tricky to get back out...but dosen't make nearly as bad a mess. I also stretch a trash bag from directly under the filter to the drivers side wheel well to catch any spillage.
    ***This only works when the oil/engine is COLD.***
    Oh, and any spillage only helps lubricate things/protect it from rust
    Veteran Member Four Rings Tone-Dogg's Avatar
    May 06 2007
    2020 Q3 P+
    Hartford, Connecticut
    Get a pella extractor & change the filter from the top, done in 5 mins.
    2016 Q5 3.0T Quattro P+ Sline Black Optic
    2020 Q3 2.0T Quattro Premium +
    Dec 19 2007
    York, PA
    i think its easier from the top, thats just me.
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    I did mine when installing my K04 last week for the first time ever. You just reach in there however u want (from the top or bottom) I had to reach from both since it was tight and I didn't have a strap tool. Then you fill up the new oil filter with some oil and screw it back on. Not hard at all and I'd never done an oil change on my own car before.
    REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
    Jan 11 2008
    UK
    i cant find the oil filter............. any pics?
    Sep 24 2007
    Woodbridge, Ontario
    Look somewhat under the coolant resovoir youll see a big black filter about 10 inches long
    Sep 24 2007
    Woodbridge, Ontario
    Jan 11 2008
    UK
    Quote Originally Posted by audipotential View Post
    thanx for all your help! every1
    Sep 24 2007
    Woodbridge, Ontario
    No prob bob
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    First loosen the filter a bit and then put 2 grocery bags around it to catch the oil, minimizing the mess.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Buy your own oil/filter and go to Jiffy Lube. You will get a receipt for the oil change with your VIN on it. This will come in handy later down the road.
