Results 1 to 6 of 6
    Veteran Member Three Rings RAUDIS6's Avatar
    Oct 09 2006
    Stage 3 B5 S4, LS460, Mini S Countryman
    Finished the fronts, need some help for the rears
    I think my rear brakes are FUBAR. I replaced my rotors and pads in the front, no problem, business as usual. I go to replace the backs, and the frickin caliper bolts are rusted shut. I finally get them to budge, now they just spin, and spin, and spin. They do not come out, hence can not get the caliper off to change the pads. Now I go to tighten them, and yup, they just spin.
    What the hell did I do?, or better yet what do I need to do now? I just put the twheel back on, and raod test, same as before, but a little uncomfortable with those bolts just spinning freely.
    By the way, this is on a 02 C5 S6 Avant.
    Thanks!!!
    Senior Member Three Rings massboykie's Avatar
    Mar 14 2008
    '16 Audi S6, '16 Audi S5 Cab.
    Natick, MA
    Re: Finished the fronts, need some help for the rears
    Quote Originally Posted by RAUDIS6 View Post
    ...I finally get them to budge, now they just spin, and spin, and spin...
    Hey Raudi
    On the rears you need to hold the gide-pin with a wrench while you are turning the pin itself. I am nto positive on the brakes for the S6 though.
    Have a look in here, I'm pretty sure it will be in there.
    http://www.vaglinks.com/Docs/Audi/C5...akeSystems.pdf
    Cheers
    Massboykie
    2016 Audi S5 Cab. - ECS Intake, K&N DI
    2016 Audi S6 - K&N DI, 10mm VCDS drop+12mm Spacers, Disc Italia+HPS 5.0
    Not to be forgotten...
    2016 Audi A3 2.0T, 2006 Audi A4 Avant 2.0T, 2002 Audi A6 2.7T, MKIV VR6 GTI & GLI, MKIII GLX & GL Jettas
    http://www.VAGLinks.com - 2000+ VAG Links!
    http://www.PlanetVAG.com - VAG Only Search Engine!
    Oct 09 2006
    Thanks man, that should do it. Very detailed...will give it a go this weekend.
    Mar 14 2008
    Natick, MA
    That's from the Bentley... ( http://www.BentleyPublishers.com ) Worth every cent. Great to have if you work on your car yourself.
    Best prices here: http://www.bimmerzone.com/audimanuals.htm
    Cheers
    Massboykie
    Oct 09 2006
    I have one for my S4, it is the older book version. I agree
    Senior Member Two Rings rxphiler's Avatar
    Jan 22 2008
    05 Porsche Cayenne TT, 06 Ford Expedition King Ranch, 92 UrS4 sedan, 05 Volvo V50 Wagon
    Charleston, SC
    What type of wrench did you use to try to remove the rear rotors? The glide pins are regular bolts these will just spin when turned. The bolts that hold the calipers on are female hex head bolts... I did my rears this week, doing the fronts next week.
