Results 1 to 13 of 13
    Senior Member Two Rings Grk_A4's Avatar
    Sep 18 2007
    Philadelphia
    Avant to Sedan suspension swap
    Does the s-line avant suspension match up with the sedan s-line suspension? Thank you!
    Sep 18 2007
    Philadelphia
    Re: Avant to Sedan suspension swap
    bump anyone?!?!?
    Sep 18 2007
    Philadelphia
    How about it guys?!?!? Anyone?
    Veteran Member Three Rings mksap11's Avatar
    Apr 06 2005
    Boston, MA
    My guess would be "no". Avants are a little bit heavier than the sedans, and companies like Eibach have Avant specific springs leading me to believe that there is a difference.
    Sep 18 2007
    Philadelphia
    What about coilovers? Don't they just sell one set for the sedan and the avant. Someone correct me if I'm wrong. I am purchasing a 2008 s-line suspension however it came off of an avant and I want to make sure that it is the same s-line suspension that comes on the sedans.
    Sep 18 2007
    Philadelphia
    Bump! Anyone?
    Account Terminated Four Rings
    Apr 12 2007
    2010 Ford Edge AWD
    Mr. 630
    I know that KW sells two different sets of V3 coilovers.
    One for s4 sedan and one for s4 avant. They have different spring rates.
    S4 (B6) Wagon, Convertible, Quattro 3/03-(B6) 10-40/10-40
    0.4-1.5/0.4-1.5 2195
    Spring rates (lbs/inch or Progressive Spring): Front=830 / Rear=P
    S4 (B6) Sedan, Quattro 3/03-(B6) 10-40/10-40
    0.4-1.5/0.4-1.5 2295
    Spring rates (lbs/inch or Progressive Spring): Front=830 / Rear=470
    Sep 18 2007
    Philadelphia
    Oh ok. I guess the avant s-line suspension is different than the sedan then. I guess I'll have to back out of my purchase. Thanks for the info.
    Veteran Member Four Rings LAS's Avatar
    Feb 12 2004
    HI.
    the suspension with 'fit' on both. but like mentioned, some companies have particular spring rates for each, slightly stiffer for the avant's added weight. and some others like the stasis streetsports, iirc, have the same part # for both. so, depends on what/who you are buying.
    Sep 18 2007
    Philadelphia
    Thanks I think I am going to wait till I find the oem sport suspension for the sedan. Thanks.
    Jan 06 2008
    Dacia Sandero
    Arizona
    keep diggin through the classifieds, thats where i got my 08 setup with 500 miles on it. (thanks tribe!)
    B8.5 []S5 . BBS . H&R . AWE . DEVAL . Stėrn . 034 . OEM+
    Active Member Four Rings 3.2some's Avatar
    Dec 19 2007
    ..is full of crap I dont need
    Escondido, CA
    Quote Originally Posted by Grk_A4 View Post
    BAM!!!$410
    http://www.audizine.com/forum/showth...76#post2541576
    V/R -Phil
    B7 2006 Audi A4 3.2L Tip FWD Brilliant Black
    Sep 18 2007
    Philadelphia
    Thanks man I'll shoot him a pm
