Results 1 to 3 of 3
    Senior Member Two Rings Grk_A4's Avatar
    Sep 18 2007
    Philadelphia
    Sedan to Avant suspension swap
    I want to know if the s-line suspension from a b7 a4 avant is the same suspension as a b7 s-line sedan. Thanks
    Veteran Member Four Rings jeremy@matrix's Avatar
    May 27 2004
    B8.5 S4, B8 S4, B7 A4A, B6 A4, B5 A4, Q7, 958TT, 955TTS, 997C2S, 996TT...
    Portland, OR
    Re: Sedan to Avant suspension swap
    Quote Originally Posted by Grk_A4 View Post
    May be a bit stiffer spring rate on the Avant. I'd suggest calling the dealer and getting part numbers for a sedan and Avant and see if they're the same.
    Jeremy Williams
    Matrix Integrated Inc.
    www.matrixintegrated.cc
    Registered Member Two Rings
    May 19 2008
    PA
    I have a 08' A4 B7 Advant Sline Suspension on a 07' A4 B7 Non Sline Sedan. I checked with the dealer with the part numbers and they are interchangeable. Both are Quattro also. So you should be good to go!
