Originally Posted by
Reich
Only custom program in tcu. It will change pressure, change pulse width modulation on valve body and change oil. I have very good sourse from tranny guys that said tip are build for war. The guy selling the kit knows alot of thos tranny. His 8sec golf vr6 is with modified auto tranny. the only thing that could break is that stupid lock up oil seal wich is a job of 400$
I hate to be the bearer of bad news... but we have similar setups, though my motor is completely built. I am running the TiAL R650 GT kit, which also uses the stock manifolds, GT28 series components, and similar fueling. The 5HP19FLA absolutely will not survive the kind of power you will make. Mine gave up after a couple of hundred miles. (I lost 4th and 5th gears, probably due to failure of the E clutch pack.)
I have a custom TCU which is also optimized for higher line pressure and valve body pulse width. My lock up seal has been retrofitted as well. Several people have broken these gearboxes with K04s alone.
Good luck, man.. Thank you for being a pioneer.
