Results 1 to 40 of 41
    Veteran Member Four Rings 20vturbo's Avatar
    Nov 24 2004
    2004 A4 2.1t, 2015 Q5 3.0t
    MOntreal
    Anyone using 2bennett brakes??
    www.2bennett.com
    if you do post your opinion
    BetaAlphaTau member #19
    Sep 23 2006
    Houston TX
    Re: Anyone using 2bennett brakes??
    3.0 King had them. you can try PMing him.
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    I'd pass, you can buy OEM RS4 for the same $$
    Nov 24 2004
    MOntreal
    would the rs4 fit the 18inch old rs4 mags??also they have a pretty nice rear setup
    Nov 24 2004
    MOntreal
    Quote Originally Posted by 400HPA4 View Post
    buy them where??are they better than alcons??
    I have to replace the ecs, the rotors are loose on the hats and the guys at vag told me all the kits they installed had that problem
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    At any dealer or an online retailer that sells OEM parts at a discount.
    As far as being better, that would be a matter of perspective. The OEM RS4 brakes are 8 piston Brembo monoblocks with 365mm vented rotors. Everything is 100% plug and play.
    Sep 23 2006
    Houston TX
    Someone had B7 RS4 front brakes for sale on the classifieds here for a while and I don't remember them listed as sold. Probably worth searching back.
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    The only real downside to them is that wheel fitment can be a bear. You must have 18" wheels at the minumum with a offset of about 25
    Nov 24 2004
    MOntreal
    So would they fit my oem rs4 sline wheels with the ecs 10mm spacers??
    Nov 24 2004
    MOntreal
    Quote Originally Posted by Ill 3.0 View Post
    i know hence my thread thanks
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Quote Originally Posted by 20vturbo View Post
    Should
    Nov 24 2004
    MOntreal
    Should
    what size are the rs4 rears? do they use s4 caliper??
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Let me post up the ETKA screen shot for you...JAS
    Nov 24 2004
    MOntreal
    are they the same as rs6..ecs sells them for rs6 but they don't show any calipers and disks for front rs4..I guess they are the same as rs6
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Not the same part number S4 ends in a F (B6) or J (B7) Screencaps to follow
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Calipers are the same however the carriers are different (calipers and carriers come together)
    RS6 and RS4 rotors are totally different.
    Nov 24 2004
    MOntreal
    So it has a bigger disk.. Know anyone that sells them??
    Nov 24 2004
    MOntreal
    So to go to rs4 rear brakes I have to get the disk and the carriers..I can keep the s4 calipers i have right now right?
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    I cannot confirm nor deny that. When I visually saw the calipers, they looked compatible. It may be worth a shot, the worst thing that could happen is you will have to buy the calipers.
    Nov 24 2004
    MOntreal
    ok so who sells those..where would you look for ??
    Veteran Member Three Rings Nogaro_PhiDelt's Avatar
    Sep 15 2007
    2000 Nogaro S4 (Stg 2)
    San Luis Obispo/Burlingame
    www.2bennett.com
    my dad has them on his allroad. the stock brake calipers were shitty so he just threw the 2B's on.
    2000 S4 (Stage 2)
    ->APR
    ->2B H&R Coil-over Program
    ->17" Flik Lex wheels
    ->ASP Tru-Dual 89mm Exhaust
    ->RS4 Clutch
    Veteran Member Four Rings dubenvy's Avatar
    Oct 22 2006
    '14 A4 2.0tQ (wifey)
    Odenton
    i call bullshit on the RS4 setup is the same or better price.
    USP CLUB MEMBER #41
    <<Insert Clever Signature Here>>
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Retail is $2335 plus shipping
    8E0 615 107
    8E0 615 108
    8E0 615 301 AB (2)
    8E0 615 311 D (2)
    8E0 698 151 H
    Sep 02 2005
    Montreal
    B7 RS4 front brake kit for only $2335? Damn!
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Nov 24 2004
    MOntreal
    Greg put my name on one but I have to make sure it fits my 18"
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    I am just posting this info up for everybody, I am not trying to sell any RS4 brakes on here.
    OEM 18" RS4 wheel is et24
    Matrix Integrated installed a set of USP wheels on a car with 370mm Alcons, I believe they had to use 10mm spacers, the 370mm Alcons should have the same fitment as the RS4 Brakes
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    A few of the items need to be entered twice (rotors & splash shields) the last item may or may not be needed, it is the securing parts (clips) for the brake pads, they are supposed to come with the pads but often they are left out of the box.
    Nov 24 2004
    MOntreal
    Sounds good then PM me with a price also send me a list with what's in the "kit"....Lets start with he front then later on I'll do the rear...I am thinking of using tuareg rear calipers withe rs4 disk in the rear
    should I go with the oem pad or aftermarket??
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    OEM pad should be fine
    Veteran Member Four Rings SeKKeY's Avatar
    Mar 06 2005
    MKVI GTI (dd), DTM S4, B6 USP (sold), B5 1.8T (RIP)
    San Jose, CA
    thats crazy you can get an RS4 setup for that price
    USP CLUB MEMBER #10
    Stage 2++++++++ JHM B7 S4
    Veteran Member Four Rings GTMRS4's Avatar
    Sep 14 2006
    New York, NY
    Greg - can you send me pricing for the RS4 as well
    BetaAlphaTau # 18
    2007 Q7 4.2 Premium
    2007 997 Midnight Blue
    2005 Lotus Elise Magnetic Blue
    2004 B6 APR STGIII+ (SOLD but not forgotten)
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    I already posted the retail pricing up.
    Nov 24 2004
    MOntreal
    what about the splash guards I think they have ducts for cooling is it true?
    Veteran Member Four Rings golgo13's Avatar
    Apr 29 2007
    Tampa Bay
    What about MOV it??????? Does anything compare?
    SweetnLou!
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    MOV IT brakes are not really used in motorsports
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by golgo13 View Post
    I highly doubt much if anything is better than the larger Alcon's or the new Brembo M caliper kits
    Nov 24 2004
    MOntreal
    what I like about the oem one is that it's a true floating system rather than a hole and screws that hold the disk on the hat
    most likely alcon is the best one but at almost 4000$ come on
    Nov 24 2004
    MOntreal
    I hope they're not like the oem cayenne pads
