    Aug 31 2007
    2001 Audi A6 2.7t
    New Jersey
    Custom Exhaust....help?
    I cant decide whether to finish my exhasut the rest of the way back to the downpipes with just 2.5" piping or 2.5" piping and an x-pipe...what would the benefits or consequences of the x-pipe? thanks.
    2001 Audi A6 2.7t Stage 2+: Special Edition, Sport Package, Winter Package, Luxury Package, APR 93 octane program, Navigation, Bose Audio, IPP Intercoolers, APR Bipipe, 710N's, Custom 2.5" Exhaust, Piggie Pipes, Upgraded Torque Converter, Stage 2 Darintake, ABD Racing big bore intake, H-sport sway bar kit, Slotted/Drilled Rotors
    Nov 19 2005
    Pair of (. )( .)
    Re: Custom Exhaust....help?
    x-pipe: the way it will sound
    -Andrey
    Stanced and Tuned Brilliant Black RWD C5 A6 2.7T 6MT
    Senior Member Three Rings massboykie's Avatar
    Mar 14 2008
    '16 Audi S6, '16 Audi S5 Cab.
    Natick, MA
    Quote Originally Posted by asm72ecko View Post
    I would keep the x-pipe in there... The way I look at it is that the engineers put it there for a reason, and they know more than me, so I'll keep it... lol
    I believe the x-pipe enhances flow by allowing two paths for the gas to follow. Not sure if this is a very scientific explanation, but I'm sure a search on Google can get that cleared up..lol
    Cheers
    Massboykie
    2016 Audi S5 Cab. - ECS Intake, K&N DI
    2016 Audi S6 - K&N DI, 10mm VCDS drop+12mm Spacers, Disc Italia+HPS 5.0
    Not to be forgotten...
    2016 Audi A3 2.0T, 2006 Audi A4 Avant 2.0T, 2002 Audi A6 2.7T, MKIV VR6 GTI & GLI, MKIII GLX & GL Jettas
    http://www.VAGLinks.com - 2000+ VAG Links!
    http://www.PlanetVAG.com - VAG Only Search Engine!
    Senior Member Three Rings skiroad'r's Avatar
    Apr 21 2008
    2002 allroad Tip, 2005 Mazda 6 Wagon 5MT
    Central New Jersey
    the x-pipe balances out the flow from each cylinder bank and I THINK reduces drone.
    '02 allroad 2.7T Tip
    ASP Flash, 034 Snub Mount (DIY), VAST EFK (DIY), H-SPORTS (Hard)
    Anrott Gen II Front Airsprings (DIY), Magnaflow mufflers with 3.5" tips
    Summers: Yokohama Avid W4S/RS6 Reps
    Fog DRL's, Toggable 628 Relay, Tip Override Recode, Remote Window Recode, Clear Corners (DIY)
    Timing Belt DIY (at 60K miles), Tiptronic Drain & Refill Service DIY (at 62K miles)
    GET OEM PARTS HERE: http://www.europaparts.com/
    Nov 19 2005
    Pair of (. )( .)
    check my signiture, there is a link of my setup with x-pipe.
    -Andrey
