Results 1 to 25 of 25
    Veteran Member Four Rings TighTT's Avatar
    Feb 21 2006
    Widebody'd avant with AZR 3.0 TTE 950+
    NJ/NYC
    Valeo E-code question.....*pics added*
    So....on the Valeo S4 e-codes:
    I know the hole in the bottom is where the OEM balast would go. But what if you are using an aftermarket HID setup and the ballast doesnt fit into the opening? What do you use to close-up the huge opening??
    50% Blood
    50% Sweat
    50% Forced Induction
    Thats 150% motherf*cker.
    Veteran Member Four Rings 20A4Audi1.8t01's Avatar
    Oct 08 2005
    '16 SQ5 '07 Corvette
    Orlando, FL
    Re: Valeo E-code question.....
    I just left mine as is
    -Brilliant Black 01.5 A4 1.8T Fronttrack Tip-
    GIAC Hammer KO4|APR TIP|Modded Carbonio V2|RaceTec FMIC|Forge 007p|SPP EFK|PSI TP|TT 2.5 DP|Custom 2.5 Magnaflow Exhaust|15% LLumarTint|215/40/18x8.5 RS4 Reps/Nitto Neo Gen|Ecodes|RS4 Grill|H&R Coils|Rieger Roof Spoiler|Pioneer AVIC-D3 NAVI|Cadence 10|JL Audio A6450|Almani door speakers|Cadence amp|8000K HID|3000K HID Fogs|In Pro mirrors|S4 Front/Skirts/Brakes|Cupra R lip|Apikol snub|All Red Tails|Shaved Euro Trunk
    Feb 21 2006
    NJ/NYC
    Quote Originally Posted by 20A4Audi1.8t01 View Post
    With a huge hole in the bottom?!?!? I dont want moisture issues.
    50% Blood
    50% Sweat
    Veteran Member Four Rings Silverstreak98's Avatar
    Dec 11 2006
    Minnesota
    The OEM kit is only $270 from hidconcept, works great and fits perfectly in there. If you haven't already bought I would just get that.
    I have the OEM kit in mine, and I love it works perfectly and looks like it came that way from that factory.
    ~Brian
    1998.5 A4 2.8QT
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    I had the same problem when I switched from RS6 ballasts in halogen housings to S4 housings where those ballasts just didn't fit. I bought an oe set of S4 ballasts, ignitors, and bulbs and used them to seal the holes. My intention was and still is to eventually run the high beams with the S4 stuff and add a 50-55w 4300k low beam setup. Mega lighting.
    Jim
    I Do Werk.
    Mar 09 2004
    nw michigan.
    The other option is to cut some plastic and seal it in place but that is kinda hokey. I tried it before buying the S4 electronics and it just didn't work well for me. I used plastic similar to milk jugs and sealed it with RTV but some of the RTV didn't set and got real messy.
    Jim
    I Do Werk.
    Oct 08 2005
    Orlando, FL
    Quote Originally Posted by TighTT View Post
    yeah I have the TYC ecodes mine is sealed off where the ballasts mount. I don't have an open hole havnt had any issues with moisture. but urs is open to the housing????
    Feb 21 2006
    NJ/NYC
    Hmmm. I really want a 55 watt kit....so OEM is a no-go. Looks like I need to do more research.
    50% Blood
    50% Sweat
    Mar 09 2004
    nw michigan.
    This link shows the different ballast types. You need the 5GL style.
    Like this .
    I think I paid about 200 for the ballasts and ignitors.
    Jim
    I Do Werk.
    Active Member Three Rings lowestA4's Avatar
    May 08 2005
    hanover germany
    I have two OEM ballasts for the B5 in stock. Shall I pm you some pictures? These would seal the cutout perfectly (-:
    Jens
    Aaah ok. Sorry! I just read OEM is a no go for you. Delete my post
    lowestA4 -- Germany based parts collection & experienced overseas shipping since 2004. German engineering meets passion.
    Feb 21 2006
    NJ/NYC
    Quote Originally Posted by lowestA4 View Post
    Jens
    Pm me anyway....I just might go OEM afterall.
    50% Blood
    50% Sweat
    May 08 2005
    hanover germany
    Ok. I'll do so tomorrow or on saturday in worst case. We have evening already in germany.
    Thx.
    Veteran Member Four Rings Lazer Viking's Avatar
    Nov 06 2006
    garage ornaments
    southeastern pa
    how is the ballast holder different on ecodes then it is on us spec housings ?
    because just thinking what mine look like, i dont see a way that would leak
    -Nic
    My Car
    old junk new junk, red junk blue junk
    Oct 08 2005
    Orlando, FL
    exactly I didnt think they were any differant either.
    Feb 21 2006
    NJ/NYC
    Quote Originally Posted by pacman View Post
    My car came with two piece headlights....so I cant make comparisons to those. I'm currently running Halogen E-codes with xenons retrofitted on. The new Xenon E-codes have a large hole on the bottom of them where the ballast mounts. This hole leads directly into the housing. My question is:
    If one decided to not go the OEM route and buys aftermarket HID's (which have a ballast that are shaped differently than OEM) what covers up this huge (maybe 4 inch X 3 inch) hole?? I think Onemoremile is the only one that understands what I'm saying.
    50% Blood
    50% Sweat
    Veteran Member Four Rings diegomatrix's Avatar
    Jun 04 2005
    das auto
    just cover it up. all HID headlight housings come like that w/ the hole for the ballasts.
    i think it would be better for you to get the 55w ballasts instead of going for oem ballasts that came w/ the B5. there really is a stark difference in the performance and you'll prolly be regretting/thinking about them after you've gone the oem route.
    you can get pieces of plastic from home depot or somewhere, and then bond it to the bottom where the hole is.
    Nov 06 2006
    garage ornaments
    southeastern pa
    fiberglass it up, if you dont care about permanently modifying the lights
    -Nic
    My Car
    Feb 21 2006
    NJ/NYC
    Quote Originally Posted by diegomatrix View Post
    Thats what I figured. Any suggestions as to a good 55 watt kit??
    50% Blood
    50% Sweat
    Mar 09 2004
    nw michigan.
    the ones i've been looking at are from apexcone. just make sure you get something with good reviews and a solid warranty.
    Jim
    I Do Werk.
    Feb 21 2006
    NJ/NYC
    Quote Originally Posted by onemoremile View Post
    Ordered. I'll let you know how they work!
    50% Blood
    50% Sweat
    Feb 21 2006
    NJ/NYC
    Re: Valeo E-code question.....*pics added*
    Here is a pic of the huge hole:
    50% Blood
    50% Sweat
    Established Member Two Rings Flash's Avatar
    Oct 13 2006
    Earth
    I'd just roll on down to homo depot, buy a piece of thin gauge metal, cut it out with aviation shears, drill some holes and seal with silicone or similar. You could even use lexan that they sell there if it's thick enough.
    Feb 21 2006
    NJ/NYC
    Quote Originally Posted by Flash View Post
    Hmm...Im diggin' the lexan idea. Where in HD to the sell this stuff??
    50% Blood
    50% Sweat
    Veteran Member Three Rings Bic-Ball's Avatar
    Mar 29 2007
    Is the street.
    Long Island, New York
    i had some formica laying around that i cut up, spray painted, and drilled some holes in for zip ties. i sealed it in with caulk
    it was a real tight fit underneath, i ended up removing one set of zip ties.
    Oct 13 2006
    Earth
    Last time I bought some it was near chain link fence/gate hardware on a back wall somewhere, IIRC. But they had pieces from 1/16 to about 3/8 thickness in sizes all smaller than 4'x4'. You could always phone them up and ask. I've seen it at other hardware stores also, Lowes etc. I've also seen solid (opaque) colored acrylic in larger sheets, but lexan would be better as it's more flexible.
