Results 1 to 13 of 13
    Apr 03 2008
    Collingswood, NJ
    Rear spacers ONLY??
    I've noticed a common combination for our cars is 5mm spacers up front and 15mm spacers in the rear. I'm actually happy with where my front wheels sit now though so is it safe for me to assume that 10mm spacers will flush the rears with the fronts? I don't need/want my wheels flush with the arches. I'm just afraid that once I go lower, the lack of "pokage" in the rear will really stand out.
    2006 Audi A4 Avant 2.0T QM6 - Revo Stage I, A8 Fat Fives, 18x8.5, 45ET
    2003 Audi A4 1.8T QM5 - OZ Racing Operas 17x8, 35ET
    2007 Kawasaki Ninja ZX-6R - stock
    Active Member Four Rings Maverick's Avatar
    May 03 2007
    german
    heaven/hell
    Re: Rear spacers ONLY??
    15mm is too much for the rear if you have an offset of et35 unless you run skinner tires. otherwise it sticks out too much.
    8 9 or 10mm for th rear is good enought.
    i am going to run 9mm
    F80 M3 DCT|C250 Coupe|i3|16 RS7
    B6 A4 3.0 back to stock |B8 S4
    E46 M3 Heavily Modded IR/Black Cloth - track car
    E46 M3 TiAg/IR Moton/GC Track Ready - sold
    E92 M3 Melbourne Red/Black cloth/CF Roof - Exported
    E93 M3 AW/Black Sold
    E39 540iA Minor front end mods. Smashed|E39 540iA Aggressor - sold
    W126 1989 560SEC Totaled
    Bentley Continental GT Black/Black Mulliner Package - sold
    Porsche 944 NA - totaled
    Sep 02 2005
    Montreal
    Quote Originally Posted by kirby View Post
    I haven't. People usually put no more than 5mm difference between the front and rear spacers. Ideally, using the same thickness all around isn't a bad idea, as it preserves wider front wheel base, compared to rear, which helps with understeer.
    Sep 02 2005
    Montreal
    Quote Originally Posted by Maverick View Post
    Not when you run ~2.0 neg. camber.
    Veteran Member Four Rings sambrody44's Avatar
    Dec 28 2007
    2002 Audi 1.8TQM
    Woodstock, NY
    Camber FTW.
    "set your mindstate free"
    2002 Audi A4 1.8TQM
    Lowered by Stasis SS (finally) On 19" ADR M-Classics.
    Bailey's DV
    Neuspeed Short Shift
    Southbend FE SS Clutch with AWE Flywheel (13lbs lighter then stock)
    Buy my photos here.
    May 03 2007
    german
    heaven/hell
    i know, but fewer people are the type that pay to play.
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    I run a 5mm spacer on the rear only.
    No problems.
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Dec 19 2007
    York, PA
    ^whats the offset?...i was going to get 15mm for the rear and 10mm for the front..im still running oem sports.
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    Quote Originally Posted by n7plus1 View Post
    18x8.5 ET35 wheels with 235/40/18 rubber.
    Appearance: OEM+
    Registered Member Two Rings Avus Bub's Avatar
    Feb 10 2007
    London UK
    I'm running 8mm front and 10mm rear. Wheels are OE 8x18 ET43mm
    The 8's were on the rear only, then I bought the 10's too.
    Before-
    8mm-
    No issues.
    HTH
    BUB
    -=UK 2004.5 A4 S-Line Quattro Avant 190ps=- Avus Silver/Silver Half Leather-Brushed Alloy Trim-GmbH Body Kit-18" Five Arms-Xenons-Bose-SymII+ -R Sensors etc etc.......
    Std DSMIC.Oettinger Alloy Intake.HyperBoostHX.K&N Panel.Milltek Cat' Back,100mm Tips.Neuspeed Snub.Strat' Shortshifter.KW V1 Coilovers.B7 RS4 22mm R Sway Bar.B6 S4 Front Brakes & Goodridge SS hoses DOT 5.1. OE S4 Mirrors.B7 RS4 Pedals & Handbrake Grip.Re-Mapped to 240ps & 345nm
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    It all depends on what the offset of your wheels are.
    In my opinion (whether it be with or without spacers) you want to get your offset as close to 35mm (32mm ideally) as possible.
    Here are my wheels with a 35mm offset (no spacers used, but I would like to have 32mm offset instead
    -Sami-
    Apr 03 2008
    Collingswood, NJ
    Quote Originally Posted by Avus Bub View Post
    8mm-
    BUB
    Looks like we have a winner. That's exactly the look I'm going for.
    Jan 08 2008
    Montreal
    imo 5mm and 20mm would look dope :D
    btw, i got some fo sale too :D pm me
