Results 1 to 8 of 8
    Mar 19 2008
    Audi, Porsche, VW, Ford
    Great White North
    Is the radiator support the same for all b5 A4s?
    I need a new radiator support for my 2001 Audi A4 Quattro 1.8T. I'm wondering if I can fit any rad support from any year and any engine B5 in there?
    I'm concerned about the headlight change and fender change in early 1999.
    I think the Turbo rad support is also different?
    Please confirm! - especially if anyone has access to part numbers.
    Thanks for all your time!
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Re: Is the radiator support the same for all b5 A4s?
    I am wondering the same thing. I repaired mine but would like to replace it eventually. All the ones I've seen on ebay and parts sites are for a V6.
    Jim
    I Do Werk.
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    my eyeball tells me yes. i can find out for sure later this evening.
    Mar 19 2008
    Great White North
    I'm very curious. The reason I ask is that on some of the Ebay-listed aftermarket rad supports, some say for V6 cars, some say Turbo cars. Also, there's an intercooler pipe that runs under the radiator that the V6 cars don't have.
    Thanks for any info!
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    There are at least 10 different ones, not even counting the RS4 one.
    Different combinations, whether fitted with aircon or not, 4/6 cylinder versions, facelift or pre-facelift etc.
    Oct 17 2004
    Columbia, SC
    he is correct.
    i checked, lots of part numbers.
    i am pretty sure you could make one fit.
    Mar 09 2004
    nw michigan.
    That is the big question. Not are they different, but are the interchangeable? Can the V6 core support be used on a 1.8t car?
    Jim
    I Do Werk.
    97 A4 2.0TQM
    Rochester, NY
    the v6 one isn't designed for the turbo crossover pipe..it has a different snub mount setup too.. you can use it, but you need to buy a euro engine bracket that bolts up in place of your air conditioning (you'd have to lose the A/C)
    qfrog on AW did it when he converted his 96 to a 1.8t.
    it has a different tow hook too.
