Results 1 to 11 of 11
Thread: MAF question
    Dec 05 2007
    MAF question
    I am pretty convinced my 02 sensors have sh*t the bed (getting ~19 mpg and it is not cool. Figured I should replace anyways now and see if that is the culprit). I just ordered replacements and was wondering about the MAF. If that was calling it quits on me too, would my dash throw a CEL?
    Veteran Member Three Rings BONFIRE074's Avatar
    Aug 13 2007
    Re: MAF question
    i think with our cars you can unplug the maf and it will run off the map, not positive, someone else can chime in
    2004 Subaru Impreza WRX
    Aspen White
    Veteran Member Four Rings tdn's Avatar
    Aug 29 2007
    2001 1.8tqm, mkIII 2.0
    Paktia, Afghanistan
    Re: MAF question
    I'm pretty sure thats only for 2001 and up. So for the original post, this is true. For you its not.
    As for the original question, your MAF can be dying on you, but won't throw a cell until it causes a problem. If you've got vag com, log block 002? 115? I forget.. but if you do a search you'll find threads about logging your MAF readings and what it should be reading.
    Correct me if I'm wrong.
    Dec 05 2007
    Re: MAF question
    Well, if my car can still run effecient without the MAF then it is really futile to even replace? Unless I get a CEL, then I will get a new one just to get rid of the light.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: MAF question
    I was getting 20 mpg recently and was throwing a lean code. I logged the MAF and decided to change it. Now I get over 25 avg mpg and like 30 on the highway.
    If you don't get a code for 02 sensors (primary is what you really want to replace) then they are fine. Log your maf if you can.
    Dec 05 2007
    Re: MAF question
    I figure I will just replace all 3 as it would be needed to get done sooner or later anyways. Got the sensors for pretty cheap. Less than $100 brand new Bosch for both and am now looking for MAF.
    Aug 29 2007
    Paktia, Afghanistan
    Re: MAF question
    It's not running efficiently. Yes you should replace it. You will get a cell, p0102 I think.
    Where did you get o2 sensors so cheap? Hook me up!
    Oh yeah, how many miles are on your car?
    Dec 05 2007
    Re: MAF question
    I have 112k. But here is the link for the sensors. If you don't mind ebay. I got quoted $109 each somewhere else. And I think he would have sold me 2 of the same, but the AWM uses 2 different sensors.
    Established Member Two Rings EOD-5's Avatar
    Apr 20 2008
    98 A4 1.8tQ, 1990 Miata
    Newark, Delaware
    Re: MAF question
    just bought 2 off that guy...bosch universals for my 98...came to 52.50 shipped...awesome....
    now help me find a cheap MAF :)
    1998 Audi A4 1.8tQ 5 Speed
    VVME 4300k, RS4 Grille, GIAC, Piper Cams, APR TIP, Blinktek Heatshield, Forge FMIC, Catch Can, TurboXS BOV, PowerGasket, ECS FP Gauge, VDO Boost Gauge, ATE Slotted Rotors, PBR Pads, RubberTite Floor Mats, 034 Coil Cover
    1990 Mazda Miata
    not stock
    Dec 05 2007
    Re: MAF question
    Quote Originally Posted by EOD-5 View Post
    I just got mine for $67.50 shipped brand new(link). But I got lucky with that one. Here is list for your car. But make sure you get correct one. Read the details on the ads. My stock part number is 06A906461LX. The 'X' is is for replacement and the 'L' before that is for my engine code. Your part number will be similar to this, maybe a different letter instead of the 'L'.
    You should take your Vin number and call the dealership to get your part number as not to get the wrong one. That is what I did. And you should really get a new part and not used. I do not see a new one on the list provided, but used ones if you decide to go that route. Just keep checking ebay everyday (type in "98 A4 Air Mass" and it should pull up list) till you find a new one for cheap. You will come across one eventually. Like I said, I just got lucky.
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: MAF question
    I shelled out $150 for my new MAF and that was through a discounted dealership price. You can buy used ones at a junkyard for like $50.
