    Registered Member Two Rings peregrine's Avatar
    Jan 09 2008
    2005.5 2.0T Quattro
    Fog mod for the B7...
    Is there a way to do the fog mod by using the fuse box? I had this setup on an older C5 A6 where I could have my fog lights run independently from the low beams.
    I'd did the fog mod for my B6 but they stayed on all the time from when you turn the ignition on. I used the Canadian soft code but I want to control when to turn them on.
    Can anyone help?
    Nov 12 2007
    Grand Junction, CO
    Re: Fog mod for the B7...
    Search the DIY. There is a DIY on this. You can run your city lights and fogs at the same time. Takes some basic rewiring, and not on the fuse box. It's on the wire harness connected up to the light switch.
    Apr 18 2008
    Jacksonville, FL
    from another citylight/fog thread recently updated: http://audizine.com/forum/showthread.php?t=188467
    i did this and it worked great to allow fogs with citylights. now i just need to VAG off the amber front corners...i think...i kinda *like* the ambers...
    2011 Toyota Tacoma Double Cab SR5
    SOLD 10/2011
    2008 A4 Avant 2.0TQ Tip in Quartz Grey
    APR Stg 1; RS4 Rear Sway; 034 Turbo Inlet Pipe; 35% tint; 640 SWITCH mod; GROM-I2-VAGD + Proclip
    Apostrophes: how to use them Baby Jesus cries when you misuse apostrophes.
    Veteran Member Four Rings Glassnpowder98's Avatar
    Mar 07 2008
    Audi A4 B7
    VA
    Awesome. I had tried to get my tuner shop to use the VAG-Com to program the fogs with the amber corner lights. They were able to get it to work but it messed with all my other headlight settings so I had them reset the codes. Are the B6 and B7 headlight controls the same? Also, I saw that once you do the copper and the tape, you still have to VAG-Com the "rest of world" code. Would that be... ###21? for Bi-Xenon with DRL and "rest of world." I got that based off of the FAQ thread. Oh yeah, I know nothing about coding with the VAG-Com if you haven't figured that out already... I was just trying to have the code ready so that when I bring it to the shop they can code it. Thanks!
    Euro Headlights & DRL
    Module 09 (Central Electrical), recode to ###XY, where:
    X = DRL
    0 – Halogen without DRL
    1 – Halogen with DRL
    2 – Bi-Xenon with DRL
    3 – Bi-Xenon without DRL
    4 – Bi-Xenon with DRL / tail light / license plate light
    Y = Locale
    1 – Rest of World / Nordic Countries / Denmark / Croatia / Baltic Countries with Bi-Xenon
    2 – Nordic Countries / Denmark / Croatia / Baltic Countries without Bi-Xenon
    3 – USA / Canada with Bi-Xenon
    4 – Canada without Bi-Xenon
    5 – Special Vehicles
    05.5 A4 2.0T Brilliant Red 6MT: Put some money and time into it...
    The only standing start, straight line racing I enjoy is on the way to the first corner.
    Apr 18 2008
    Jacksonville, FL
    ###21 looks right, but i didn't VAG mine, and i've got halogens :( Give it a shot, just remember to write down the original values so if it isn't right you can return it to stock.
    SOLD 10/2011
