Results 1 to 7 of 7
    Veteran Member Four Rings tamadrumr88's Avatar
    Nov 03 2006
    lehigh valley pa
    Unorthodox means of replacing rear diff bushings?
    About a year ago I went to install the stern rear diff bushings. I was using a hydraulic press and the first bushing came out fine (a tad loud, but came out clean nonetheless) while the second (I believe it was the passenger side) put up a struggle. In the end the bushing did not budge and I ended up cracking the collar around the bushing (it's white aluminum so it's obviously not the strongest material known to man and I did not want to have it repaired because the heat from welding could possibly further weaken the material).
    48 hours later I locate a spare rear diff crossmember at a cost of $60 and I attempt the same thing, ultimately cracking the passenger side collar of the rear diff mount while trying to remove that damned bushing. I curse myself, and my audi, and vow to never again attempt this procedure. I purchase yet another rear diff carrier and decide to stick with the stock rear bushings even though they clunk like a beast.... so I'm out $120, ~6hrs of my time, and nothing has changed.
    Fast forward to today, I decide I want to again take on this behemoth. What are my options? Should I try first cutting the metal insert out first, remove the remains of the bushing, and try to press the metal sleeve out with a hammer/flathead screwdriver??? I've heard that pouring lighter fluid on the bushing and setting it ablaze may loosen things up a bit
    Any other ideas? I really hope that the third attempt is successful
    Feb 27 2005
    North Wales, PA
    Re: Unorthodox means of replacing rear diff bushings?
    hhmmm would take a torch and just burn them out.
    Nov 03 2006
    lehigh valley pa
    How do you suggest removing the metal sleeve around the bushing inside of the collar??? If that doesn't come out the new bushings won't press into place
    Veteran Member Three Rings 1NaudiA4's Avatar
    Feb 13 2007
    98 A4
    Chicago
    very careful with a saw zaw might work. I used a dremel with a hammer and chizel... worked wonderfully.
    Senior Member Three Rings Solaris's Avatar
    Feb 01 2006
    NC
    I used a hacksaw to remove mine. Just be careful not to cut beyond that metal sleeve.
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    drill the shit out of them first. then chisel. then screwdriver.
    Veteran Member Three Rings black00A4's Avatar
    Oct 19 2006
    Ontario, Canada
    I used a heat gun, got them so hot they turned to plastic haha. Your best bet is heat but watch out cuz it stinks.
    2000 Audi A4 2.8L Quattro Sport - Volcano Black
    Mods: 18" A8 Rep's, Ebay SS & Strut tower bar, PureMS Snub mount, K&N, MAF de-screened, H&R sports, STERN power ring & diff mounts, Cupra Lip, DEPO ecodes, Unitronic flashed ECU, Magnaflow
