Results 1 to 11 of 11
    Veteran Member Four Rings Louis J.'s Avatar
    Dec 26 2007
    PNWR
    Question Upgrading brakes for track: Please help
    Crosspost from the B7 A4 cousin hoping to find some good input here.
    My first track day on the A4 is coming up and I'm starting to think about brakes. The track is technical with lots of braking required and while I don't want to spend $2k on a BBK, I also don't want to nanny them for fear of toasting them.
    Can I get away with an aggressive fluid like Castrol SRF, steel lines and pads (Hawk HPS maybe?) or do I need to look at upgrading the calipers and rotors too? If so, should I just do the fronts or do I need to do the rears too? Can something like Porsche 993 or 996 calipers work? I think they're 4 piston too. I was also thinking of looking into Touareg calipers since a tech mentioned he's done an upgrade using massive Cayanne calipers (sounds expensive though).
    Also, any ideas on increasing airflow to the brakes? I think this is a key issue since there seems to be no flow. I was thinking of cutting out a hole on the wheel liner and ducting to scoop and direct air from the fog grilles to the brakes. Anyone tried anything like this?
    TIA
    Black B7 Titanium - Sold
    APR93 | Carbonio | Vogtlands | RS4 sway | Abt quad-tip | Podi | BBS RCs w/RT-615s | RS6s w/W300s
    Veteran Member Four Rings earhythmic's Avatar
    Sep 17 2006
    ‘17 F450, ‘24 Street Triple RS
    San Francisco Bay Area
    Re: Upgrading brakes for track: Please help
    I dont have any solid input on brake kits or lines or anything...BUT! I did come across this DIY for adding brake ducts. It's kinda a ghetto fab but it'll work on the track without putting too many holes in the body right? here's the link
    http://www.audiworld.com/tech/wheel27.shtml
    2013 Allroad - 12.18s 1/4 mile
    CTS K04| APR | IE | Magnaflow | AirLift 3H | Hotchkis | Vorsteiner
    clicky for build thread
    past: B6 S4, B5 A4
    Dec 26 2007
    PNWR
    Thanks for the link! I don't care if it's ghetto so long as it works well. I'll go over it tomorrow in more detail. Cheers.
    Veteran Member Four Rings channad's Avatar
    Oct 14 2007
    2008 S4 DTM; 2017 Q7 Prestige
    Mammoth Lakes, Ca
    ChannaD aka Techno Dad | New DJ Mix | New YouTube Video!!
    2012 Q5 - Black | Black | Premium Plus | S-Line | Nav | B & O
    2008 - DTM | Sprint Blue Pearl | Black leather/Alcantara | Navi | CF trim | OEM 18" RS4s
    Veteran Member Four Rings 2PUTT's Avatar
    Nov 09 2005
    UBIQUITOUS
    why not just do a StopTech stage 2 kit for your car?
    www.zeckhausen.com - call and ask for Dave. he will gladly answer your questions.
    2009 Audi Q7 TDI
    2001 Audi S4 Avant
    CHALLENGE MW
    AWE | AWE | AWE
    Senior Member Two Rings wva s4's Avatar
    Jan 19 2008
    Charleston,WV
    did my first event in April with just a fluid and pad change.
    Hawk HPS and good fluid and I had no problems at VIR.. use the money on sway bars and suspension if you havent already you will be glad you did, at least I was.
    Oct 14 2007
    Mammoth Lakes, Ca
    ^^^^^ hey, I know that picture! You're on AW also!
    Dec 26 2007
    PNWR
    Thanks for the great feedback guys. I've done some homework this afternoon and have narrowed things down a bit. Firstly, I should say that won't be doing much tracking, which I guess I should've specified before. I'm gunning for around three events for the year plus a dozen autox events.
    Here's what I'm thinking now...
    Carbotech pads - probably X6 or X8
    Castrol SRF fluid
    Nuspeed SS lines
    Ducting the brakes to keep them cool
    I may also do the S4 upgrade to bigger rotors and carriers but haven't decided yet. If I do it, I'll go with something crossdrilled and slotted.
    Whadaya guys think???
    Jan 19 2008
    Charleston,WV
    yeah I have been more of a reader than a poster, but after 8 years of reading and 4 great Audis I thought I may be ready to contribute a little.
    Louis be prepared it becomes an addiction and the track makes it worse....:)
    Veteran Member Three Rings quattro.it's Avatar
    Mar 24 2008
    2004 BMW R1150RT
    Bellevue, WA
    Pads and fluid are plenty for the # of track days you have planned. Put money into suspension. Once you develop your skills you'll find you use more finesse on the brakes to post faster lap times. Take advantage of the instructors if you're new to this.
    2007 A4 2.0T quattro Tip S-Line Titanium / Lava Gray / APR 91 /
    Dec 26 2007
    PNWR
    Thanks for the well wishes guys and for the record, I'm no noob to motorsports...I'm just new at putting my one-month old A4 on the track...addiction took root long ago. I've already got suspension and today I found a set of light weight wheels and tires for track. RS4 sway is going in next week. The issue with brakes is that I don't plan to keep the car for very long so I don't want to spend too much time or $$$ modding but do need to set things up so the car can work properly.
    I'm also not new to Audi as I've had two S6s in the past, I just never tracked them since I didn't get involved in motorsports unitl after I had sold them and had gone through a few other sporst cars.
