Originally Posted by
RolledMySTi
Great looking product and sounds sweet too without waking up the neighbors.
I have apr downpipes which are 2.5", do you know if your cat back would connect to them?
Also the web sites says the RS6 fueling and tuning is ready, any specs or prices?
I bolted the first cat back I did up to APR 2.5" dowpipes with no issues. So you should be fine.
As for the RS6 setup and tuning here you go.
--Turbos--
-RS6 turbos w DP flanges = $3333
-K04 inlets (if you don't already have them) = $550
-Turbo Hardware = $80
Check them out on my site for DP options.
http://www.shop.jhmotorsports.com/pr...&productId=135
--Fueling kit--
Tuning, JHM Plastic 90mm MAF (Made it fit the RS4 airbox and looks stock), RS4 airbox, RS4 MAF hose, Siemens 60lb injectors, 3 bar FPR, Manual Boost Controller (in car adjustable units now available for an extra cost), 255lph fuel pump, Bosch platinum sidefire spark plugs ($15 each), associated clamps/hardware for ventilation system/intake, oem paper air filter (K&N available for $65 or use yours from your stock airbox since they are the same), fuel rail hardware, updated coolant sender/o-ring/clip. =
$2387
That way the turbos, hardware and fueling kit can be had for $5800. Then only $550 more for the K04 inlets if you don't already have them. So $6350 if you need inlets as well.
