Results 1 to 15 of 15
    Registered Member Three Rings SlappyB6's Avatar
    May 14 2008
    W-S, NC
    Unhappy Audi Newb, help!
    Okay, I posted this on another forum, but have gotten no replies after almost a week. Anyhow...
    Recently purchased a 2002 A4. Love the car, but I'm having some issues. One, I have a CEL. I work at a dealership, had them read the codes and got the wonderful P0420 code. So naturally I need to replace the cat. Any good aftermarket ones for not a lot of money? The dealer has agreed to pay for repairs as long as I can keep the cost under $700.
    Second problem. I hear kind of a "whomping" noise when driving. It seems like it's coming from the rear end, and it increases with speed. It also is much more noticeable at lower speeds. I was thinking it was an off-balance tire, but then I started to see a lot of what looks to be dirt and grease on the back tires. So now I'm thinking bad CV boots? Or could it be something else?
    Thanks for any and all input!
    Dec 06 2007
    Re: Audi Newb, help!
    1.) a high flow cat would be a good idea! probably $200 or a testpipe if u don't mind a bit more noise $100
    -Kirk
    BetaAlphaTau Member #58
    May 14 2008
    W-S, NC
    I thought about a test pipe, but I have emissions to worry about here in NC. Is there a way to "deal" with that?
    Sep 03 2007
    park
    high flow cats are only $200?
    Sep 02 2005
    Montreal
    High flow cats provide about 0whp gain.
    Dec 06 2007
    ^^forget it then!
    -Kirk
    Sep 03 2007
    park
    Why the hell is it called a "high flow" cat then if theres no gain?
    Veteran Member Four Rings jrau13's Avatar
    Mar 12 2006
    02 Mercedes ML, 04 Avant 1.8t
    Costa Mesa
    It just has a lower cell count which is supposed to be "high flow" but they aren't any better or worse than a tp. You wont get the sound of a tp and they are generally a lot more than $200.
    I'll keep my money,
    My Guns, My Freedom,
    & you can keep the CHANGE
    Mar 12 2006
    Costa Mesa
    You could always get the test pipe then when emissions time rolls around reinstall the cat.
    I'll keep my money,
    May 14 2008
    W-S, NC
    My inspection isn't due until December. I was thinking getting a test pipe with a full exhaust, and then eventually order a cat and just throw it on when I have to get my inpsection.
    And ideas on the other concern? The brakes feel fine, and I don't notice any other concern besides the noise. And the noise seems to get louder after I drive a while, and then slow down. So I'm thinking it might be the CV boots, and once everything gets heated up, that's why I tend to hear it more at certain times?
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    If your car has less than 80k miles/8years, the cat should be replaced under the federal emissions warranty...unless you want to go aftermarket.
    http://www.epa.gov/obd/warranties.htm
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
    May 14 2008
    W-S, NC
    Oh, I'm quite aware of that. But my A4 has 109K miles on it right now. I appreciate the info though.
    May 03 2005
    Boston
    D'oh. No problem!
    EPL S2 + TCU
    Previous Cars:
    Sep 07 2007
    San Francisco, CA
    Btw, Techtonics Tuning sells a HFC for $350 I think. Not cheap, but it's definitely less than $700.
    May 14 2008
    W-S, NC
    I was thinking of doing this:
    I want to get an exhaust, and I have a local shop that I've had 3 previous vehicles to, and they do damn good work. I'm going to buy the test pipe, have them install it and do the exhaust, and get the stealership to pay for whatever. Then at some point before December I'll pick up a new cat to install for emissions.
    As for the other problems, I'm still at a loss. I guess I just need to pop the back wheels off and see what I can see.
