Results 1 to 10 of 10
Thread: Is it enought?
    Veteran Member Three Rings davidlizard's Avatar
    May 01 2008
    2004 A4 ultrasport 6speed
    Winter
    Is it enought?
    HI guys,
    I know probably many thread on this subject but I want your Idea. For sure, I'm going to buy a front mount intercooler and an exhaust very soon. Im running a 2004 USP 6 speed with the stock K03. Is it a good idea to switch the K03 for K04 and TT injectors and in both case, will a test pipe give a big difference. Does anybody run this kind of set up? How much power from this set up??money is not really a limit, I just want more power and reliability. I dont want to change my engine rods and pistons ... I fear big turbos for reliability..
    Veteran Member Three Rings Carlitos's Avatar
    Sep 17 2006
    B6 A4 1.8T
    San Juan, PR
    Re: Is it enought?
    for k04 you need:
    k04 turbo: ~$750
    380cc injectors (or TT 225's): ~$225-350
    Software: Apr, Giac or Revo. $500+ BI file (if you don't have a software)
    FMIC and TP are optional but you won't get the best of the k04 without them.
    btw, SEARCH!! there are a lot of thread about this! you will find everything you need.
    FlexTuning
    Amulet 1.8TM
    BAT#46
    May 01 2008
    Winter
    Re: Is it enought?
    I'm not asking what do I need... I want to know about people how has this setup how they like it and if it,s a good setup for the price, or should I only run the K03 FMIC and hexaust... clear??
    Senior Member Two Rings [IX]'s Avatar
    Mar 09 2008
    Florida
    Re: Is it enought?
    I am running the following setup.
    APR1+
    TT225
    Evoluion Front Mount
    Forge 007
    Tantrum TestPipe
    Carbonio intake (eeeehhh) don't waste the money
    Custom 2.5" Thermal exhaust
    Neuspeeed Bushing
    Plus suspension Mods
    Here are recent numbers
    http://pictureposter.audiworld.com/111598/k03_31508.jpg
    My avice go bigger first.
    I am doing KO4 Neuspped xtreme TIP and 034 Manifold in June
    <<NO SIG>>
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    Re: Is it enought?
    big turbos are going to be more reliable than a k04.
    the homebrew'd s4
    Dec 06 2007
    Re: Is it enought?
    ^^[IX] that is 263HP and 317Ctrq!!!!!!!!!!!!!!!!! thats like WOOOOOOOOW! for a 1+ setup thats like WOOOOW!
    -Kirk
    BetaAlphaTau Member #58
    Feb 17 2005
    Sarasota, FL
    Re: Is it enought?
    Bigger turbo's are for losers! K03 FTW!
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Re: Is it enought?
    My full K04 setup lasted in my car for only 10 months before I went BAT.
    But then I am far from being your normal Audi owner.
    Sep 03 2007
    park
    Re: Is it enought?
    Quote Originally Posted by [IX] View Post
    APR1+
    TT225
    Forge 007
    Tantrum TestPipe
    Neuspeeed Bushing
    damn !!!!!
    Jan 10 2007
    VA
    Re: Is it enought?
    Not really. Those numbers are from a dynojet, which reads much higher than say a dynodynamics. So you cannot simply multiply by the same number to estimate crank power.
    OP: Lots of people run that setup. FMIC, Exhaust, Test pipe, TT injectors...either with the K03 or the K04 and of course appropriate software. Both are a lot better than stock, and the K04 has more power and torque. These are great if you want a quicker car with a similar powerband. A BT will make you much faster, however you lose low end power.
    Quote Originally Posted by AudiA4Turbo22 View Post
