I searched for some of the codes here but none have an answer. I got these after doing seafoam in the intake manifold however I don't think its linked.
18057 - Powertrain Data Bus: Missing Message from ABS Controller
P1649 - 008 - Implausible Signal - Intermittent
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 004 - No Signal/Communication - Intermittent
65535 - Internal Control Module Memory Error
00-00 - -
18256 - Please check DTC Memory of Engine Controller
P1848 - 35-10 - - - Intermittent
01312 - Powertrain Data Bus
79-10 - Please Check Fault Codes - Intermittent
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to B+ - Intermittent
01316 - ABS Control Module
49-10 - No Communications - Intermittent
Do those codes mean my ABS module is done for? For the coolant temp fault, is that linked to the recall that was recently sent out? Also it won't even let me clear some of them ex. P1649, P1654...
