Results 1 to 10 of 10
    Dec 14 2006
    Halifax, NS, Canada
    Convert to Stock HID
    A friend of mine is going to go to some junk yards in the UK for me. I am looking for all the parts numbers/names for what i need from a euro S4 to convert my A4 to have oem ecode hid. I am always forgetting exactly what you need.
    2001.5 1.8T Manual Quattro Celebration | Startup Racing Vogtland Coilovers | Giac X Chip | SPP A pillar with VDO Gauge | Boxster/A8 Front brakes S4 rears | Neuspeed Catback VMR Testpipe |
    NOW DEAD :(
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Re: Convert to Stock HID
    The headlight assy itself should be all... Unless you want to do the auto leveling crap which would NOT be worth it IMO...
    ΜΟΛΩΝ ΛΑΒΕ
    Dec 14 2006
    Halifax, NS, Canada
    yah so i need the headlights, and the box thing (ingnitor?) and the ballasts?
    NOW DEAD :(
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    headlight housings, ballasts, ignitors, bulbs. You will also need either the leveling motors and control or the little white plastic pieces that take their place in non-HID models.
    Jim
    I Do Werk.
    Dec 14 2006
    Halifax, NS, Canada
    what do those plastic peaces look like?
    how hard is it to install the leveling stuff?
    NOW DEAD :(
    Mar 09 2004
    nw michigan.
    White plastic, about 30-35mm in diameter, hex for allen wrench molded in the middle. The motors took me awhile to get in there. They have a ball on the end which fits into a keyway while the motor has to mount and twist into it's mount. It is pretty tight in there and can be frustrating but eventually they just fall into place. I assume the white plastic pieces are easier but I haven't tried those.
    Jim
    I Do Werk.
    Dec 14 2006
    Halifax, NS, Canada
    Im going to get etka working again so i can figure this out
    Do the OEM HID require rewiring or is it plug and play?
    NOW DEAD :(
    Mar 04 2007
    nothing
    nowhere
    Plug n' play
    ΜΟΛΩΝ ΛΑΒΕ
    Account Terminated Four Rings
    Jan 09 2008
    B5 A4 Quattro 4,2L V8 6 Speed
    United Kingdom
    All you need is the headlamp. In the UK, both HID and non-HID one-piece headlamps come with the levelling motors in place.
    And complete with the ballasts too. I fitted them to my '96 car, all I had to do, was replace the connector with a facelift one, the wires are all the same colour, so no issues there. Everything works, including the leveling, which my car had before anyway. Only difference is, my pre-facelift had a seperate plug for the motors, facelift models are incorporated into the main D-shaped plug.
    Only plug-and-play on facelift models.
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    The Euro turn signal plugs are little different too. They still have the triangle shaped connectors, but they are positioned a little different. So when you go to plug the turn signal in it may take like 10 minutes like it did me. You kinda have to finagle it to get it in. Eventually it goes. Thats how my RS4 headlights are
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
