2003 B6 3.0 Quattro
OEM rear lights
I've searched every conceivable rear light issue config to no avail however I did find one that suggested swapping all bulbs for new so I did that and here I am.
Oddest thing going on with the rear lights and I'll do my best to lay it out clearly.
Friday of last week - turn the car on and get a "left rear light" out message before heading out of town for the weekend. Stop and pick up a bulb from Autozone and it was a "lighting tech" bulb number 7506. Replace the bulb in the parking lot (doesn't look bad). Message light doesn't go out. Hmmm.
Drop wife and daughter off at hotel a couple hours away and go to another AZ I saw on the way in. Get another 7506 - match up the numbers to make sure I didn't monkey finger it. Replace bulb - reassemble. Start the car and message light doesn't go out.
Go home on Saturday evening. Match new bulb with old bulb. Same info. Disassemble both lights and switch all bulbs from left to right and vice versa. Reassemble - now the only thing that works is right blinker, rear fog and nothing else (brake light in rear window is fine). So the right which had no issues at all - now has most everything out when I put it back together.
Go to Pepboys pick up all new Sylvania bulbs for both lights - bend all contacts upwards a little, apply die electric grease (which i've never used before on bulbs in all my years) reassemble and same. Doesn't fix anything - no brake lights, left turn signal, hazards, running, etc.
Disassemble to the point the lense was removed but the harness was still plugged in, turn on lights - make note of the 3 out of 11 that work, turn car off, swap them for the other side, turn car back on and the same 3 worked in the same 3 locations with different bulbs!? So in essence a bulb that wasn't lit on the left side, now works on the right side WTH?
I checked the fuse (#14 and #31) and both are fine. What gives?
Any insight is appreciated!
