Results 1 to 14 of 14
    Veteran Member Three Rings TalipseAWD's Avatar
    Apr 08 2007
    Stamford, CT
    Diagnose a Bad Ballast?
    Hey guys, more problems.
    I ordered Bulbs for my car, because one was dead.
    So i get the bulbs and I put them in, The one that was blown is still out.
    So now Im more frustrated than Ever before, because Im sure I will have to Buy a new ignitor or something else that will cost and arm and a leg.
    Where should I go from here?
    Audi Dealer and have them Diagnose the Headlight dilema?
    Try to find the other ignitor and put it to the "bad" headlight and see if it really is the ignitor?
    OPEN to suggestions.
    HELP!
    2000 S4
    Established Member Two Rings caall99's Avatar
    Oct 02 2007
    Boston Area
    Re: Diagnose a Bad Ballast?
    Funniest thing happened to me. I cracked the driver's side headlight assembly (minor accident) and continued to drive it the way it was. One day we had some serious rain and the light bulb got fried from water leaking into the housing (or so i thought!). A couple days later I scanned and cleared my codes and it immediately started working again. Coincidence?
    2000 Audi S4 Black/Black
    XS-Power Turbo-Back Exhaust * APR Stage 2+ V5 93 Octane * 710Ns * AWE DTS * Short Shifter * Stern Power Ring, Rear diff. mounts, snub mount
    Apr 08 2007
    Stamford, CT
    So your saying have my car scanned and all codes cleared and maybe itll work?
    Its worth a shot. before I pay for a new ballast
    2000 S4
    Senior Member Three Rings S4shpion's Avatar
    Jul 04 2007
    New- 23 RS3 | Old -01 S4
    Chicago
    i have similar problems, my driver side will flicker and then go out on me. I turn it off and then turn back on it works. So intermiddent that it sometimes it will flicker but not go out for days and sometimes it will go out immediately and when i try the on/off it will either work or piss me off. Im going to open the ballast and see if it has any corrosion inside and see if i can clean it , if not im going to order a new ballast.
    2023 Python Yellow RS3
    Tech, Sports Exhaust, Carbon Fiber Package, Black Optics, 30% tint, IGL Kenzo ceramic coated.
    Sold
    2001 Brilliant Black StageII+ TIP S4 ..
    Giac-X, Piggie Downpipes, Vibrant Exhaust, Koni|Vogt shocks|springs, 710ns, Samco TBB, SPP dimpled|slotted black zinc rotors | Hawks HPS street pads, 35% tint all around, 18"s OZ Ultraleggaras.
    Apr 08 2007
    Stamford, CT
    Just said Fuck it and ordered another Ballast. I need to get this damn car able to drive at night or im gonna go crazy.
    I ordered a cheap one now, to see if that the problem, and If that solves the problem I will get some good ones.
    2000 S4
    Oct 02 2007
    Boston Area
    Link me the cheap one? interested to see what makes it cheap.
    Active Member Two Rings rskelme's Avatar
    Oct 23 2006
    Past: 2002 Audi S4 Stage III
    Ft. Lauderdale, FL
    Did you check the fuse? Each light is individually fused. My passenger side low beam keeps popping its fuse. I'm going to check for a short and if I can't find it then look at swapping ballasts with the driver side to confirm it is a bad ballast. If the ballast is on its way out I'm going to order the 55W HID upgrade kit. It's $190 and comes with two new bulbs, two new ballasts and a lifetime warranty on everything.
    Apr 08 2007
    Stamford, CT
    It was the fuse.
    I wish you had posted 30 min earlier LOL.
    Well now I have a cheap HID ballast for sale $50 Shipped.
    2000 S4
    Jul 04 2007
    Chicago
    Quote Originally Posted by TalipseAWD View Post
    It was the fuse.
    Might be interested. Who makes the ballast?
    Sold
    Apr 08 2007
    Stamford, CT
    Quote Originally Posted by S4shpion View Post
    Some no name brand.
    I will see exactly what it is once it gets to my house.
    2000 S4
    Oct 23 2006
    Ft. Lauderdale, FL
    The fuse blew for a reason. You might want to hang on to the new ballast just to rule out a possible short. My fuse will last 1-2 days leading me to believe it is a short. If the ballast was failing I would think it would be pretty consistent and happen sooner.
    Veteran Member Four Rings will175's Avatar
    Apr 25 2007
    Las Vegas..Hawaii..Nor Cal
    I have 2 extra oem ballast if needed..
    Veteran Member Four Rings jamestown478's Avatar
    Dec 24 2008
    2000 S4 stage 2+ on meth
    Milwaukee
    Quote Originally Posted by rskelme View Post
    where can I get this $190 55w upgrade kit?
    __________________
    2000 S4 SRM K24's
    2002 Audi TT, 225q
    2012 VW Tiguan
    2013 VW Jetta
    Apr 13 2008
    Tennessee
    Quote Originally Posted by jamestown478 View Post
    DDM tuning has a kit for $100 shipped
