Results 1 to 8 of 8
    Dec 17 2007
    MI
    Rough Idle HELP!!!!!!!!!!!!!!!!!!!!!!!!!!
    Need some help. I replaced my valve cover gasket, spark plugs, cabin filter the other day. Car was running fine. I cleaned my engine. Car was running fine. Maybe about an 1 after that, my car started idling rough. I checked the vacuum hoses, and intake hoses. I re-seated the connectors to the mass flow and intake. I even reseated the battery connections to try and reset it. I allowed it to run for a while and noticed smoke coming from inside. I pulled over and stoped and noticed that the exhaust pipe that connects to the cat (after the cat) was burning like a coal on a bar-b-q. I let it sit for a couple of hours and applied water. I ven let it sit over night just in case. Woke up this morning-same thing. Rough idle. Do you think my cat is clogged? I don't know. Need some help........
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    Re: Rough Idle HELP!!!!!!!!!!!!!!!!!!!!!!!!!!
    do you have any codes?
    cleaning an engine usually means ignition issues.
    if you are seeing smoke you could be overheating the cat due to extra HC's in the exhaust from misfires.
    Dec 17 2007
    MI
    What are HC's? I am a nOOb, so excuse me for asking. What can I do until I get the VAG Tool for codes?
    Established Member Two Rings EOD-5's Avatar
    Apr 20 2008
    98 A4 1.8tQ, 1990 Miata
    Newark, Delaware
    hyrdocarbon levels
    its an emission thing....http://www.epa.gov/oms/invntory/over...drocarbons.htm
    1998 Audi A4 1.8tQ 5 Speed
    VVME 4300k, RS4 Grille, GIAC, Piper Cams, APR TIP, Blinktek Heatshield, Forge FMIC, Catch Can, TurboXS BOV, PowerGasket, ECS FP Gauge, VDO Boost Gauge, ATE Slotted Rotors, PBR Pads, RubberTite Floor Mats, 034 Coil Cover
    1990 Mazda Miata
    not stock
    Dec 17 2007
    MI
    What do I do next?
    Oct 17 2004
    Columbia, SC
    Quote Originally Posted by offroader1006 View Post
    see above
    Veteran Member Three Rings audinutt's Avatar
    Jan 11 2007
    2001 A8l 2001 A4TQM Avant
    texas
    Try pulling your coils and check for condensations, has happened to me the day after an engine cleaning.
    -richard
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    Dec 17 2007
    MI
    Thanks!! I pulled the coils and had a foul plug....probably from engine cleaning. Replaced and the car is fine... Thanks guys and gals(if any)
