Results 1 to 3 of 3
    Registered Member Three Rings turbo4s's Avatar
    Mar 27 2006
    AUDI B7 S4 / MKV GLI
    35K and just an oil change
    I went for my 35K and they did the polin filter and an oil change. I wish they did spark plugs or other things that really count. Does anyone know if they change spark plugs at 45k. If not I think im going to change them. What do you guys recommend.
    _______
    Artic White B7 S4 Fully Loaded
    Mods= Titanuim RS4 Grill
    Salsa Red MKV GLI Fully Loaded
    Mods= Revo Stage III KO4, Carbonio, AWE Full Exhaust, AWE FMIC, H&R spring & Sways, AWE Vent Guage,
    ECS Blacked Out Coners, ECS Snub Mount, KMD Fuel Pump, KMD Cam Follower
    Veteran Member Four Rings b00st's Avatar
    Oct 17 2004
    04 B6 S4, 08 RX350
    St Charles, IL
    Re: 35K and just an oil change
    used NGK on my bro's B6 s4. the process probably only took 45 min from start to finish.
    The RIDES:
    2015 M3 - BM3 stage 2
    2011 335 Msport - FBO + E85 sold
    04 S4 - JHM 93oct Tune | JHM Piggies | FI CB | JHM Intake Spacers | JHM Stage 4 Clutch | JHM LWFW | JHM LW Rotors | Snub | K&N | 034 Density Motor Mounts |SOLD
    99.5 A4 PC16 K04 - SOLD-
    http://www.cardomain.com/ride/2404758
    AMA Member
    JHMFTW!!
    Nov 04 2006
    05 S4
    LI, NY
    spark plugs are done at 55k...they should have done an air filter thou
    Oetty roof spolier // FI Catback // Ecodes // Xenon Interiors // Solaris and LED Exteriors // Lower Euro-grille // ECS Snub // PSS9s // 19x8.5 BBS CH on 245 Potenzas // Euro RS4 Exclusive shift knob and Pedal Set // Carbon Fiber Trim // Custom Carbon Fiber Emblems
    Originally Posted by Justincredible
    "With the flux mod you can just put the supercharger in the trunk for extra traction"
