Results 1 to 18 of 18
    Established Member Two Rings Jimbobdaga's Avatar
    Mar 11 2008
    Leominster, MA
    Ecode install Q's
    Alright so I picked up some ecodes from the Classified section and I tried installing them and ran into some problems. I tried searching but I couldn’t find anything related to this issue. If you look at the pictures below you will see the wire on both my stock headlight and the ecode headlight that provides power to the Ballast. As you can see the wires are on different locations on the harness. So I tried it out anyways and when I start the car up I get a “Left Dipped Headlight” error. Can this be related to the wire’s? Unfortunately when I was moving everything back into the stock headlight I dropped the light and now have to buy a new one, so I don’t know if the headlight went bad during the transfer.
    and I need to buy a new bulb, what do I need to buy and can i buy these at autozone?
    Thanks for all your help guys! (see below for car info if needed)
    NOW: 2012 A4 2.0t | Black on Black | stock for now .. more to come :)
    PAST: 2004 A4 1.8t | Black on Black | APR Stage 1+ | Audi Sport Suspension| Neuspeed Exhaust | Ecode Headlights | Forge DV
    Veteran Member Four Rings Silverstreak98's Avatar
    Dec 11 2006
    Minnesota
    Re: Ecode install Q's
    I don't believe Autozone sells HID bulbs. I would buy at an OEM reseller online, but definitely don't buy through the dealer, as they charge upwards of $200 a bulb!
    ~Brian
    1998.5 A4 2.8QT
    Veteran Member Four Rings EUROaleksey's Avatar
    Aug 10 2007
    Toronto, Ontario
    xenonpros.com for bulbs.. fast shipping, high quality product, ok price
    Mar 11 2008
    Leominster, MA
    Quote Originally Posted by Silverstreak98 View Post
    Wow that was a expensive mistake. Any one have any links for a good place to buy the bulb?
    Edit: Thanks EUROaleksey for the link
    Dec 11 2006
    Minnesota
    Xenonpros doesn't even sell D1S bulbs.
    It is very hard to find Osram D1S bulbs (philips is a little easier to find). A quick search, and the cheapest I could find a NEW Osram D1S bulb, was ~$140, so I'm guessing it will be well over $200 at the dealership.
    There are used ones on ebay for ~70, but then it wouldn't match your other bulb because the old one will be colorshifted to me more blue (this happens about 500 hours runtime on a bulb). I could only find two places that sold these outside of ebay.
    Here is the link to the place I would it cheapest: CLICK
    D1S bulbs are more expensive than D2S bulbs due to the built in igniter.
    ~Brian
    1998.5 A4 2.8QT
    Aug 10 2007
    Toronto, Ontario
    wait does he need D1S?... oops me sorry... do all ecodes take D1S D2S only?
    Mar 11 2008
    Leominster, MA
    Thank you very much. These ecodes keep getting more expensive by the minute.
    Aug 26 2005
    Regarding the different ballast power supply connectors, assuming you have two of each type, all you need to do is swap the connectors. Use a dulled needle, and carefully disengage the clip inside each terminal slot to allow the wire terminal to be removed from the connectors. Do the red wires then the brown wires or vise versa. Capicse?
    Veteran Member Three Rings scorneil's Avatar
    Oct 27 2007
    Oakville, ON, Canada
    cheaper alternative is to get a Philips bulb
    http://www.hidconcepts.com/Bulbs-Philips4K.html
    2010 B8 S4 Quartz Gray S-tronic Black Alcantara MMI
    2003 B6 A4 Canvas Beige 1.8T Tiptronic 1+ SOLD
    Dec 11 2006
    Minnesota
    Quote Originally Posted by scorneil View Post
    Exactly, but you would need to buy two, since the output from the bulbs does look a tad bit different.
    I wouldn't want to run one Osram, and one Philips at the same time unless absolutely necessary.
    Have used both I do prefer Philips though.
    ~Brian
    1998.5 A4 2.8QT
    Oct 27 2007
    fo sho, but some people might not be that anal so it's an option. probably 99% of the peeps on here would be that anal though (me included)
    Dec 19 2007
    York, PA
    you should always replace both at the same time, that goes for all bulbs...its just a rule of thumb
    Dec 18 2006
    03 A4 1.8t | 04 IB M3 SMG
    Hanover, NH
    I have 2 extra sets of D1S bulbs if you want to buy them
    Now: RNS-E | Debadged | GIAC 1+
    Soon: Caractere front and sides | S4 Rear | S4 Doorblades | Bi-Xenon E-Codes
    Future: GTRS BT Kit | Tip Tranny upgrade for BT Kit
    Veteran Member Three Rings ewytt's Avatar
    Sep 19 2006
    2016 SQ5, 2012 Turbo Beetle
    you have 5G ballasts and 5GL are what the ecodes use. I am in the same boat but don't want to mess with wires. I will probably get a set of ballasts (190) from Akinaboy for my fix so i can switch back later with ease. (when i sell)
    2016 SQ5 || 2002 Turbo Beetle
    Mar 11 2008
    Leominster, MA
    Lol and I would be part of the 99% anal, so I'm going to have to get two most likely.
    Quote Originally Posted by 47Ronin View Post
    How much for two bulbs?
    Capicse, Time to call in the buddy's that know what their doing. I don't trust my self.
    Aug 26 2005
    "Jimbobdaga", PM sent...
    Dec 11 2006
    Minnesota
    Quote Originally Posted by n7plus1 View Post
    Well if both the bulbs are brand new and he breaks one before using it, then he could just replace one.
    I think that is the case that he is in.
    ~Brian
    1998.5 A4 2.8QT
    Mar 11 2008
    Leominster, MA
    Nope I'm using the bulbs from my stock xenon's, but I took care of ordering the bulbs. Now I just need to fix my wires and I'll be good to go.
    any recommendations on a good way to smooth out and get rid of the "dimples" (can't think of a better word) on the headlights?
