Results 1 to 4 of 4
Thread: No Start....
    Senior Member Three Rings Avant1.8BT's Avatar
    Nov 05 2006
    mycar
    No Start....
    This is the 2nd time this has happened to my car since going BT.
    i drove my car all weekend and everything running perfect, then drove home from lacrosse practice let the car cool down, shut it off, showered, got back in and wouldnt start. the 1st time this happened my fuel pressure was all messed up so then i put my stock fpr in and it started, then put my adj. one back in and tuned it with a gauge correctly. i tryed doing that this time and it was a no go. pulled my plugs they where black and wet. all my coils are working, each cylinder is getting fuel, cranks over good, and thats about it. no codes.
    99.0 aeb
    2871r elim
    uni 440 file
    help!?
    thanks.
    Nov 05 2006
    mycar
    Re: No Start....
    Update, car started this morning. first crank, really rough idle for the first minute then was fine, and i smelt a lot of gas i figure that just from trying to start the car last night. CEL came on while the car was warming up, will give you guys a code when i can it.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Re: No Start....
    Wet plugs aren't sparking. Got old plugs?
    Jim
    I Do Werk.
    Nov 05 2006
    mycar
    Re: No Start....
    ok so, CEL went away i drove the car easy for a day hten drove to work this morning. went to start it up around 12 (been sitting for 4hours) and started for about 5 seconds with a bad idle then died. now it wont start, just keep cranking, any ideas?!!? i have no tools in my work parking lot or anything.
