Results 1 to 11 of 11
    Veteran Member Three Rings dak360rt's Avatar
    Apr 17 2008
    Sacramento, Ca
    Another day another CEL
    So i took my car to carmax to get the o2 changed and i was boosting on the way home because i love it. everything was great
    The next morning i start the car and i hear a big vacuum leak, i popped the hood and there is some sort of a T fitting or valve or something that has broken. I tapped it and the the suction snapped back into place and held there till the car turns off. So every morning i have to tap it back into place so the car wont miss and the CEL wont come on.
    So after my novel what is that part so i can replace it. There is a rubber fitting centered on the firewall that has a hard rubber line that zig zags down to the T fitting or valve that is broken i can pull it apart by hand.
    Thanks
    Marty
    Light Silver Metallic - 2001.5 S4 - APR Stage 2+
    Piggy Pipes --- CC Mod --- Darintake --- Samco TBB
    AWE Boost Gauge --- 1 touch rear windows up
    JHM Weighted Shift Knob --- JHM Solid Short Throw Shifter --- Custom Straight Pipes
    Veteran Member Three Rings Paulyworld1432's Avatar
    Dec 07 2007
    Houston, TX
    Re: Another day another CEL
    New piece is like 150 bucks cause it comes with that hardline that zigzag's. This happened to me so i just got some heat resistant epoxy from home depot and glued that thang up!
    Veteran Member Three Rings Jsmooth65's Avatar
    Aug 10 2007
    '15 BMW M235i, '04 A4 1.8t
    Castle Rock, CO
    Most likely the big burly hands at your local mechanic broke it because it was brittle. Make them fix it.
    2004 Audi A4 Sedan, Auto, Black, 1.8T Beater
    SOLD - 2007 Audi S4 Sedan, 6spd, Sprint Blue, JHM tune, JHM trio, JHM LWFW and stg3 clutch, Magnaflow RS4 exhaust, LED tails, TTRS SW
    DEAD - 2000 Audi S4 Sedan, 6spd, Laser Red, FRANKENTURBO Stage 3 VAST Fueling (25psi), ER Intercoolers w/shrouds, SSAC DP and Twin 2, JHM trio, APR Bipipe, VAST Stage 3 clutch and LWFW, Sterns mounts, 034 ICM delete/coil conversion, Vogtland coilovers
    Jun 14 2007
    2000 S4
    Connecticut
    i had to read that twice, are you talking about this....
    the brake booster valve?
    Dec 06 2007
    Calgary, AB, Canada
    ^^Yes he is, and yes, the epoxy method is by far the most cost effective
    Apr 17 2008
    Sacramento, Ca
    no actually not that one, if you follow that hard zig zag line down it comes to a T with another hose and the connector there is a plastic valve (for lack of a better word)
    today at lunch i hit boost and and a bump and the connection came apart and i lost power brakes and it started missing pretty bad, so it makes sense that it would have something to do with the power brake booster.
    sorry i dont have a camera Blackberry 8820 FTL
    Marty
    Dec 06 2007
    Calgary, AB, Canada
    Are you talking about the spider hose with the PCV valve that goes into the Y pipe?
    The brake booster hose and fitting do look different on the 01.5 than it does on the '00 in the pic above...are you sure it's not that one?
    Apr 17 2008
    Sacramento, Ca
    Its really hard to see because it sits behind and under the y pipe, like i said the part that is broken is attached to the other end of that rubber hose that is circled in that pic up there.
    Thanks for the help
    Marty
    Apr 17 2008
    Sacramento, Ca
    okay i figured out how to get pictures on here
    Here is a shot of the zig zag hard line that goes down to the part that is actually broken
    And here is a shot at where that oragne part on on the zig zag hose plugs into thats broken
    Hope this helps, again thanks for the help
    Marty
    Dec 07 2007
    Houston, TX
    Yep thats the f***er! if you want the part number i can give it to you, or just epoxy it
    Apr 17 2008
    Sacramento, Ca
    yeah whats the part number, im going to have to get those pricks at carmax to fix it. Then i plan on never taking it there for service again, its just all free during the first month.
    Marty
