Results 1 to 15 of 15
    Account Terminated Four Rings Gundem's Avatar
    Nov 08 2005
    A4 2.8 Type-S(low)
    Los Angeles, CA
    Is this a sign of my control arms biding farewell?
    when i brake i hear a *cling* under my footrest. when i press gas and let go i hear that *cling* again. it only comes from the front left side...
    Senior Member Two Rings deux321's Avatar
    Oct 21 2004
    2001 a4 1.8tqms
    central cali
    Re: Is this a sign of my control arms biding farewell?
    not sure if thats the control arms!might be wrong!
    the way i heard is to turn your wheel all the way to one side and accel slowly, if you here some clicking then then it would be the arms. same the other way.
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    Quote Originally Posted by deux321 View Post
    if you hear clicking that's axels...control arms and TRE's clunk over bumps when they go bad
    Nov 08 2005
    A4 2.8 Type-S(low)
    Los Angeles, CA
    ^^ oh nos. how expensive would that be?
    Nov 19 2005
    WA
    650ish for all 8 control arms 2 TREs and sway bar links, plus associated hardware. You can do it your self and save $$$ on labor.
    Axles I believe are 130 a side, give or take a few bucks.
    2017 Platinum Gray Metallic Golf Alltrack SEL
    Dec 05 2007
    CA LA
    lift one corner and check for a torn boot. if its torn then change the axle.
    if it all looks good grab your tire at 12 and 6 and wigle if its got play then you got bad bushings and need new control arms.
    please corect me if im wrong about the control arm test. that is how i was told s a good way to check
    Senior Member Three Rings A4Shizzle's Avatar
    Mar 19 2006
    San Jose, CA
    Don't mean to jack the thread but if there is a creaking/groaning sound when I first turn the wheels in the morning, is that a sign of bad CAs? I changed both tierod ends and the steering fluid is full. I didn't notice any wiggle or play when I tried to shake the wheel, but its gotten worse since then. Now it sort of clunks on bumps.
    No time to mod with so many things to fix...
    Oct 28 2006
    Quote Originally Posted by A4Shizzle View Post
    could be either control arms or the power steering rack
    Nov 08 2005
    A4 2.8 Type-S(low)
    Los Angeles, CA
    check your power steering thread thief...
    Nov 08 2005
    A4 2.8 Type-S(low)
    Los Angeles, CA
    Quote Originally Posted by bass_lover1 View Post
    oh? so i should be happy if it's axel?
    Nov 19 2005
    WA
    Yea, I suppose. But if the axle is shot, and you have a higher mileage B5, I would recommend doing the control arms at the same time as the axle. Because, either way you need to remove the steering knuckle, might as well kill both at the same time.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    No need to remove the knuckle to change the axle. Turn the wheel all the way, pop an arm connection or two off and it slides right in. I don't think I even needed to pop a joint.
    Jim
    I Do Werk.
    Veteran Member Four Rings Kronic Budz's Avatar
    Oct 01 2007
    1997 A4 2.8 QM
    San Diego, California
    im starting to get clunks in the front driver side only when im turning the wheel at slow speeds, it makes a big clunk noise sometimes. And im also getting a loose little clunk noise over some bumps in the road just like i did when my control arms starting going. The anoying thing is, i replaced all my CA's TRE's and links and so now i need to get it up on a lift and check the play in the wheels again.
    uhhhhggggg.
    1997 Audi A4 2.8 QM black on black
    bilstein sports w/ vogtland sports ~ S4/sport sway bars ~ 17x8 Bremmer Kraft Br05 wheels et33~ BF G's Sport COMP 2's 225/45/17 ~ Custom Exhaust ~ CAI ~ Ebay SS ~ SS brake lines + EBC red stuff ~ 35% tint/70% front tint ~ face lift headlights w/ 5000k HID + tails ~ blacked out grill trim~ kenwood mp3 ~ Polk comp 5.25" Front mm speakers ~ Infinity REF 6.5" rear speaks ~ 10" Rockford Fosgate p2 in sealed box ~ ED nine.4 4ch. amp powering woofer/polks[/I]
    Veteran Member Three Rings Rico750's Avatar
    May 19 2007
    B7 S4| 07' R1 | 08' R6 | 09 X6 |
    Tennessee
    Quote Originally Posted by Kronic Budz View Post
    uhhhhggggg.
    seems that i have the same prob.. sounds from underneath.. must be a famous b5 thing..
    2004 S4 | 18" RS6 rep Rims | Valentine 1 | BOSE + Blaupunkt sound | K&N | H&R sport 1.2" lowering | KONI | 30% tint | FI down-pipes | FI catback 2.5" | JHM tune |
    Nov 19 2005
    WA
    Quote Originally Posted by onemoremile View Post
    Using this image and writeup, the knuckle was removed from the upper control arms. Maybe you don't need to do this step, but if you do, you're already half way to removing the upper control arms, might as well do them at the same time.
