Results 1 to 21 of 21
Thread: limp mode =/
    Established Member Two Rings SouRce4's Avatar
    Dec 02 2006
    limp mode =/
    so like i said in a previous post, i have my new chip and was boosting at 25psi for some reason. then it was starting to level out but now i beleive it went into limp mode... 5psi. how exactly do i get out of limp mode. im sad
    '99.5 A4 1.8t FrontTrack 5spd
    ST Chipped K03s :: Custom Catback Exhaust :: Bailey DV :: Custom Intake
    Koni Coilovers :: Strut Bar :: 8000k HID's
    Custom Interior :: Custom Dash and Gauges :: 30% Tints
    Blacked Out 360°
    DÜB Wehrmacht / / / Many Audi's and VDubs
    Senior Member Two Rings deux321's Avatar
    Oct 21 2004
    2001 a4 1.8tqms
    central cali
    Re: limp mode =/
    VAG it!
    see what codes it might be throwing.
    is your CEL on?
    Dec 02 2006
    Re: limp mode =/
    I would love to vag it but dont want to spend the money to buy the unit. Autozone can check my does and such but theres no way to get out of limp mode any other way... Ughhh i hate driving to get my codes cleared
    Blacked Out 360°
    Oct 21 2004
    2001 a4 1.8tqms
    central cali
    Re: limp mode =/
    well if you take to autozone, it should be able to get you the codes at least.
    then write them down and search for those codes here AZ and that should fix your problem.
    make sure that you have them give you the codes and not just erase them.
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    Re: limp mode =/
    what kind of chip did your purchase? 25psi?!?! you better not get on it until you fix the problem
    TEAM|AXION
    Account Terminated Four Rings
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    Re: limp mode =/
    Quote Originally Posted by speedydragon View Post
    25psi is fine i ran 26 on my K03 and K04. and second youre 99.5 you dont have a limp mode
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    Re: limp mode =/
    99.5's have limp...
    ΜΟΛΩΝ ΛΑΒΕ
    Veteran Member Three Rings jm121189's Avatar
    Jun 05 2007
    Portland, ME
    Re: limp mode =/
    I think only drive by wire have limp mode and 99.5 was still drive by cable.
    2000 1.8t A4 qtm gone but not forgotten
    2008 R32
    2015 S4
    Veteran Member Three Rings Rico750's Avatar
    May 19 2007
    B7 S4| 07' R1 | 08' R6 | 09 X6 |
    Tennessee
    Re: limp mode =/
    Quote Originally Posted by AudiRacerS4 View Post
    how the heck do you get that out of the k03??? please enrich me.. custom program?
    2004 S4 | 18" RS6 rep Rims | Valentine 1 | BOSE + Blaupunkt sound | K&N | H&R sport 1.2" lowering | KONI | 30% tint | FI down-pipes | FI catback 2.5" | JHM tune |
    Mar 04 2007
    nothing
    nowhere
    Re: limp mode =/
    Might want to search for "nDBW limp." It'll tell you what you need to know about pre 99.5's having limp...
    ΜΟΛΩΝ ΛΑΒΕ
    Dec 02 2006
    Re: limp mode =/
    the only reason why i called it limp mode was because i went from 25 and such to steady 5psi and thats it
    Blacked Out 360°
    Mar 26 2005
    Re: limp mode =/
    so what chip did you get? :] I wanna run 25psi lol
    TEAM|AXION
    Oct 28 2006
    Re: limp mode =/
    Quote Originally Posted by Rico750 View Post
    MBC and cranked wastegate
    Oct 28 2006
    Re: limp mode =/
    Quote Originally Posted by Ewok_Fetus View Post
    99.5's have limp...
    not for overboosting like the 2000+'s
    Oct 28 2006
    Re: limp mode =/
    my guess is the n75 since that will cause you to only hit 5psi if it goes bad
    Dec 02 2006
    Re: limp mode =/
    by any chance could a bad DV o-ring cause the same issues? cause when i lubed the dv last time, the o ring seemed stretched a little and got catch once when i was testing to see the suction
    Blacked Out 360°
    Mar 04 2007
    nothing
    nowhere
    Re: limp mode =/
    Of course... They don't have a MAP sensor, so they don't know what they are boosting... However, it is possible that he ran lean due to high boost and is now in limp because of being lean...
    ΜΟΛΩΝ ΛΑΒΕ
    May 19 2007
    Tennessee
    Re: limp mode =/
    do you adjust the nut/bolt on the waistgate lever ?
    Dec 02 2006
    Re: limp mode =/
    yes but i wouldnt do that. adjusting the nut on the wasteagate will shorten the life of the turbo. so what can i possibly do to fix my boosting issue? i will be getting my codes read 2mm but i will say that i got them checked and cleared yesterday to see if my air bag light would go out b4 i get my inspection and when checked, there were no codes from the car. hopefully i get something 2mm so that i can see what the problem is. if there are no codes tho what should i expect the issue to be?
    Blacked Out 360°
    Dec 02 2006
    Re: limp mode =/
    so just now its hitting 10psi now lol... is this probably N75 issue or DV? or any other ideas? i got the codes read and there arent any
    Blacked Out 360°
    Oct 28 2006
    Re: limp mode =/
    yes
