Results 1 to 14 of 14
Thread: Couple issues
    Dec 06 2007
    Couple issues
    Alright these problems have to be solved soon i'm tired of this car already!
    -MPG average meter resets after a couple hours of it sitting when i turn it on and start to drive it all the sudden says 0.0MPG and then starts jumping, happened after i changed my battery!
    -I feel a lot of vibration through the floor and the pedals and the steering wheel, been since i got the car, and it's not from the exhaust, it's driving me insane!
    -i get a max of 17 VAC is this normal? and my boost only spikes 19 and holds like 15! and if in 5th gear i start to pull the turbo feels like it's warming up and kinda surges on and off a bit until it starts moving constantly is this normal???
    -And for my K04 setup i plan on completely redoing my boost and VAC lines, and i want tougher tubing for it! and i think it's time to do this so any recommendations for tubing??
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Re: Couple issues
    For vac, I believe 22 is norm.
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    May 03 2008
    '03 A4 1.8TQ M5
    Auburn, AL
    Re: Couple issues
    Quote Originally Posted by AudiA4Turbo22 View Post
    If you look in one of the corners of the display while the MPG meter is up it will have a little 1 or 2 in the display. 1 is the current "temporary" meter. 2 is the "permanent" meter. The display in 1 will reset after I think 2 hours just like the trip timer. The display in 2 will reset rarely. I had mine reset when the dealer did maintenance long ago, but I have not checked it since I started doing the maintenance in my car. You can switch between display 1 and 2 by using the button on the bottom of the windshield washer stalk.
    Snub mount not seated correctly? Bad motor/trans mounts? Out of balance tire/wheel combo? Not really a lot of info to go on from your description.
    Maybe a bad DV? Or one that is on its way out.
    Dec 06 2007
    Re: Couple issues
    ^^just changed the DV, i know i have the MPG meter to the one with the circle and the line going through it the crossed out zero, thats the one reseting, and i just had my tranny support arms fixed and tranny mounts replaced, wheels are perfectly balanced and alignment is fine, motor mounts?? snub mount?? maybe?
    -Kirk
    May 21 2007
    Florida
    Re: Couple issues
    drop your belly pan and look for any redish fluid. that will tell you if you have a bad motormount.
    2018 Navarro Blue Q5
    Dec 06 2007
    Re: Couple issues
    ^^genius! gonna do that, but issue is i just did an oil change and i think they washed the belly pan, this was a month ago, would it have leaked by now??
    -Kirk
    Veteran Member Four Rings mnkyA4's Avatar
    Aug 10 2004
    The City
    Re: Couple issues
    you can try hose techniques
    http://www.hosetechniques.com/produc...oducts_id=2813
    03' 1.8T A4 Avant Tiptronic ----- SOLD!!!!
    FUTURE: 2013 Ibis White Q5 3.0T
    Dec 06 2007
    Re: Couple issues
    ^^ur the shit!!!SWEEET! cheaper than i expected and exactly what i was looking for! RED TUBING FTW!!!!!
    -Kirk
    Aug 10 2004
    The City
    Re: Couple issues
    should order before mmidnight though. Supposedly they are haivng a sale
    Dec 06 2007
    Re: Couple issues
    they'll have others! and i need to route the tubing and found out what i need and more importantly i need the cash!
    -Kirk
    Feb 17 2005
    Sarasota, FL
    Re: Couple issues
    Vac should be around -20 and 19 peak dropping to 15 is normal for any chipped k03, most actually drop lower than 15 past 5500rpm
    Dec 06 2007
    Re: Couple issues
    movin up!
    -Kirk
    Dec 06 2007
    Re: Couple issues
    bump!
    -Kirk
    Dec 06 2007
    Re: Couple issues
    Bumpage!
    -Kirk
