Results 1 to 10 of 10
    Mar 12 2008
    New York
    OEM RS4 Sway vs. S4 H-Sport..........oh I search baby!!
    I've been bored at work so I'm doing some serious surf looking for info on my subjected thread.
    I have an 06 Avant that is GIAC'd, I plan on installing co's hopefully by fall. I'd like to know what you guys think about the OEM RS4 rear sway vs. the H-sport S4 rear to tide me over.
    I know adding a beefed up sway is a band aid till I get co's but it's cheap and I can do it in the driveway. The car is not tracked and won't be but I enjoy getting on it when I can. The arse of the avant is weighy and it's starting to bug me.
    I spoke with Pure and they suggest the H-sport rear S4 sway, I trust those guys but I'm looking for some opinions, I have stock non-sport suspension. Thanks in advance
    Veteran Member Three Rings mrmeth90's Avatar
    Jun 30 2007
    Miami
    Re: OEM RS4 Sway vs. S4 H-Sport..........oh I search baby!!
    H SPORT is the way to go. From what i know the RS4 sway is not that much larger than the stock. for a real difference in feel i would get the front and back H Sport. just my 2 cents
    Veteran Member Four Rings Glassnpowder98's Avatar
    Mar 07 2008
    Audi A4 B7
    VA
    Don't know much about the H-Sport sway bar, but I ordered the RS4 rear sway bar which is 22mm compared to the 16mm stock sway bar.. There is definitely a very noticeable handling improvement and I highly recommend this mod for the money-to-performance ratio. It definitely gets rid of a lot/almost all of the understeer that a heavy quattro car will give you.I would say that this mod would probably rank just under getting your car chipped as a cost effective, yet noticeable mod.
    Last edited by Glassnpowder98; 05-13-2008 at 03:12 PM. Reason: corrected by reds-line
    05.5 A4 2.0T Brilliant Red 6MT: Put some money and time into it...
    The only standing start, straight line racing I enjoy is on the way to the first corner.
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    just to set the record straight, glass, stock is 16, sline is 18, s4 is 20, and rs4 is 22mm, not 24mm. i like the rs4 bar but the h-sport being adjustable is a plus. anyone know how hard it is to adjust it once on the car?
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Mar 07 2008
    Audi A4 B7
    VA
    ah sorry about the wrong numbers. I couldn't remember what the rs4 diameter was so I did a quick google search and the link I saw said 24mm. Oh well damn you google and bad Internet sources!
    Registered Member Four Rings Noffy's Avatar
    Sep 06 2007
    Audi A4 2.0T, Forester 2.5xl
    Portland Oregon
    If you are bored do some searching, lots of threads about this very topic. You should be able to find a good hours worth of results
    2005.5 A4 2.0Tq Quartz Grey
    Looking to purchase a euro car that I can learn to work on, and eventually take to the track for recreation days. What is a good car to start with?
    Veteran Member Four Rings audimeister's Avatar
    Jan 05 2006
    '07 A4 Avant S line Ti 6MT Quattro
    Oakland, CA
    Between my B6 and B7 (sedans), I have had stock, sport, S4, and RS4 rear sway bars coupled with stock, sport, PSS9's, Koni coilovers, and now sport springs with Koni FSD's. Stiffer RSB's are an improvement, but what you really need is balance. Hotchkiss does not recommend using their rear bar without a front one.
    BHVRDR has written about this. Unbalancing your car front to rear makes the front seem squishy and unresponsive at turn-in. Also in certain situations, the car could start tricycling, leading to snap oversteer.
    Ultimate grip and understeer are improved, but feel is lost from the front even with my RS4 RSB and stock front. I can only imagine it would be much worse by going to a hotchkiss rear bar that's twice as stiff as an RS4 RSB.
    If you want to keep your stock front, the RS4 rear is the most aggressive one I would recommend, and is right up there with chipping for bang-for-the-buck mods. Otherwise, do Hotchkiss bars front and rear.
    "Obsessed" is a word that the lazy use to describe the committed.
    Veteran Member Four Rings manhertm's Avatar
    Jan 21 2007
    "Old Yella"
    san antonio tx
    Quote Originally Posted by audimeister View Post
    I'm sure thats the case in most other cars, but the A4, S4, and RS4 all have the same size front swaybar. So, I don't think it would affect his car like that and if he does upgrade to a sport suspension, I think he'd be pretty good.
    ThetaAlphaThetaMember#1
    MY CAR IS ON AN EBAY BUDGET!! DEUTSCH REIS!
    Veteran Member Three Rings scoobycarolan's Avatar
    Nov 02 2007
    Albany, NY
    I agree with manhertm. Why would 4 model lines all have the same size front and different rears? Go for it and sell the rs4/hotchkiss when you go coilover if its such an issue.
    Scooby Carolan: Massive Audio
    2008 Ibis A4 2.0T
    Titanium | S-Line | Sport (20% Tint / Debadged)
    APR 93 octane / JHM SS / EVOms DV / Eurojet PCV
    Koni FSD / Eibach Pro-Kit / RS4 Sway
    **Join the Upstate NY Regional Group!**
    Mar 12 2008
    New York
    Thanks guys, those were kinda the answers that I expected.Bottomline is that I should get my co's
    Not for nothing four rings but I did search, I didn't find what I was looking for regarding specific car and issue so I figured that I'd ask. God forbid I ask, why you bothered posting is a bigger waste of everyones time then actually suggesting a helpful solution to a fellow member who did search.It wasnt like I asked which chip to get or some other open ended question, I was specific in my quest for a helpful solution.
