Thread: tire weight
    Veteran Member Four Rings TQMB5's Avatar
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    tire weight
    alright trying to get some new wheels and am trying to figure out a total weight for both rims and tires. Just curious what tires weight (roughly) for 18"
    ::2002 S6
    Veteran Member Four Rings chrislane31's Avatar
    Mar 24 2007
    Re: tire weight
    Tire Rack lists the tire weight
    Jun 14 2005
    Anaheim, CA
    Re: tire weight
    Are you worried about gas mileage savings? Or are you actually road racing and doing time trials? Because i would focus more on wheel weight rather then tire weight.
    -Charles@VMRWheels
    Brandon @ VMR Wheels
    Veteran Member Three Rings S4J's Avatar
    Sep 26 2006
    Nor Cal
    Re: tire weight
    Quote Originally Posted by VMRWheels View Post
    -Charles@VMRWheels
    I'd be concerned with both even though I don't track my car. Tire weights vary as much as 5lbs from brand to brand. Compare any tire to Michelin PS2's for a reference at Tirerack.
    "Will power? I've got all kinds of will power...it's the WILL NOT power I'm lacking." saj
    || MoroBlue/Silver/6sp/Prem pkg || JHM LW Pulley & Mani Spacer || APR Snub || H-Sport F/R || Bilstein PSS9's || Neuspeed SS || GIAC || K&N || Full Milltek Res || Apikol Rear Diff Mount || Ind Fog Mod || PIAA Xtreme 4150K Fogs || E-Codes || Carbotech Bobcat Brake Pads || RS4 Pedals || V1 W/Remote-mute in Shift Boot || Vellano VSQ 19x8.5 || ECS Rotors ||
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    Re: tire weight
    We weigh an example of each wheel and tire ourselves to get a better ideal of actual weights vs. manufactureres "published" figures.
