TO GET IT OUT THERE! 2001 A4 1.8T FWD with 92,000 miles. Yeah, I know. FWD. You can say it, but I love her.
I don't post too much here, I just read... a lot. Before you recommend the search function, believe me- I've spent my hours there and I'm not finding what I'm looking for (although I did discover how agonizing 30 seconds can be). I'm also going to let you know that I only can pretend that I know what I'm talking about...
Something I've noticed about tuning is that everyone does so with a very precise goal in mind. "I want to accelerate faster," or, "I want to take turns sharper," and, "I want to make more noise." What about those not-so-ambitious people who use their Audi to get from point A to point B, but want to make sure they do so as quickly, safely, enjoyably, and dazzlingly as possible. I want to wake my car up, but I don't want to harm drive ability. I want to unintentionally mumble, "wee," when I accelerate, but still be able to take a corner when the roads are wet. I want to work out a balance between output and handling, and I'd like the people who actually know how it all works to help me. <--- I'm not too good with those...
For example, squeezing horsepower out of her is one big step BUT it gets to a point that traction becomes an issue. If I want to accelerate to 60 in 4.5 seconds I'm going to be lowering her as much as possible, throwing on much wider tires, generally doing everything it takes to keep as much traction as I can. Cornering would be out of the question as I'd hit the wall every time I turned the wheel. If the road was wet I'd have to stay home because my tires would be so wide I'd just float on the puddles. There's a point where pushing power makes it impossible to expect exceptional handling. On the flip side, if I want to go for extraordinary handling I'm going to be crippled when I shoot for the rpms. 17' wheels have their drawbacks, and there's the battle between shocks and springs versus coilovers. There's struts and sway bars and a billion other things to throw on it. Where do you draw the line?
I'm asking where the sweet spot is? How fast can I make it go with wider 17" wheels? Are both front and rear sway bars going to make a difference? Should I go for the struts? What is a decent compromise?!
What I've done so far is replaced the control arms all the way around. Replaced the tie rods. Threw on S4 sway bar links. The next things I will be doing is replacing the front axles. It will be unitronic chipped once I'm done playing with the suspension and I'll be throwing in a new full exhaust. I'll also be replacing the discs and pads right after I get it chipped.
It's the "playing with suspension" that's throwing me through a loop. I want to ensure she handles well. So, should I leave it closer to factory height? Should I do coilovers or stick to nice springs and shocks? What wheel size do I stop at, 17" or 18?" Should I stagger the tires (since I'm FWD this is a very real option)? Essentially what should I do to make my daily driver a super daily driver?
Thank you for your time...
